Pioneer BDR-S11JX Help
Jwhitestick1
Post by Jwhitestick1 »
I purchased a Pioneer BDR-S11JX and had it installed. It works fine. I can't find a version of the pioneer bd drive utility that will work with this drive. I had the utility installed for the BDR-212UBK but the utility says NNo drive connected. I would like to be able to make settings chanes for the new drive but can't figure a way around this.
I am legally blind so I hope this is the correct place to post this message.
If anyone can help much thanks in advance.
Re: Pioneer BDR-S11JX Help
Jwhitestick1 wrote: Fri Aug 07, 2026 4:28 pm I purchased a Pioneer BDR-S11JX and had it installed. It works fine. I can't find a version of the pioneer bd drive utility that will work with this drive. I had the utility installed for the BDR-212UBK but the utility says NNo drive connected. I would like to be able to make settings chanes for the new drive but can't figure a way around this.
You could try: https://jpn-pioneer.translate.goog/ja/s ... _tr_pto=sc or https://www.touslesdrivers.com/index.ph ... code=56196
if its a fake drive sometimes the pioneer utility wont work
and the flood of s11jx are mostly fake crossflashes
You have the wrong utility.
Get PioneerBDR-S09-S11DriveUtility_v1.2.0.2.exe in the BDR S09 section
https://pioneer.jp/device_e/product-e/i ... iveUtility
Jwhitestick1
I downloaded the bd ddrive usility that you suggested but when i run the winrar.exe file i see: c:/users/appdata/loc
Windows is NULL
I have no idea what this means.
Can you please help me with this.
Again much thanks in advance,
J.
Jwhitestick1 wrote: Tue Aug 11, 2026 1:30 pm I downloaded the bd ddrive usility that you suggested but when i run the winrar.exe file i see: c:/users/appdata/loc
Windows is NULL
J.
What do you mean by winrar.exe? You should just double-click the .exe you downloaded.
