Verbatim 66718
salamdiab
Verbatim 66718
#1 Post by salamdiab » Thu Aug 06, 2026 7:01 pm
Hi everyone,
I recently purchased a Verbatim 66718 external slim drive.
In MakeMKV, the drive is identified as Manufacturer: Verbatim and Product: 66718 (Revision 1.00). The internal SATA-to-USB bridge is hiding the actual drive model and blocking vendor commands.
I am not sure whether the internal drive inside this specific enclosure is an LG, ASUS, or another OEM drive. I would like to flash friendly firmware / LibreDrive onto it using SDFtool Flasher, but the utility cannot recognize or flash the drive over the stock Verbatim USB bridge.
Since I cannot easily leave my main PC case open for a direct SATA connection, I would appreciate your advice on:
Is there a way to identify the exact internal drive model (LG, ASUS, etc.) while it is still inside the Verbatim enclosure?
Is there a known USB bridge chipset / enclosure (e.g., ASMedia) that allows pass-through flashing for this drive over USB?
If I extract the slim drive and connect it via a Slimline SATA to SATA adapter on another PC just to flash it, will it continue to work properly once reassembled back into the original Verbatim enclosure?
Thanks in advance for your help!
Re: Verbatim 66718
#2 Post by Coopervid » Thu Aug 06, 2026 8:40 pm
salamdiab wrote: Thu Aug 06, 2026 7:01 pm Hi everyone,
Do the last of your ideas. It will work when you put it back.
salamdiab
Re: Verbatim 66718
#3 Post by salamdiab » Thu Aug 06, 2026 9:11 pm
this is my screen shot
i can bypass and make a a nhwe firmare without open th drive
Re: Verbatim 66718
#4 Post by Coopervid » Fri Aug 07, 2026 9:32 am
salamdiab wrote: Thu Aug 06, 2026 9:11 pm this is my screen shot
i can bypass and make a a nhwe firmare without open th driveScreenshot 2026-08-06 215758.png
You need to post the text from Makemkv info. jpg is not possible.
salamdiab
Re: Verbatim 66718
#5 Post by salamdiab » Fri Aug 07, 2026 9:47 am
Hi everyone,
Following up on my previous post regarding the Verbatim 66718 external slim drive:
I connected the internal drive to a different enclosure to bypass the stock USB bridge, and MakeMKV successfully retrieved the actual hardware information:
OS device name: E:
Manufacturer: MATSHITA
Product: BD-MLT UJ273
Revision: 1.00
Serial number: WQ52 0019133CEWA001913273ABSX1
Highest AACS version: 82
It turns out the internal drive is actually a Panasonic / Matshita UJ273 slim drive.
Could you please advise on the following:
Is there any LibreDrive or friendly firmware support for this specific Matshita UJ273 drive?
Can this drive be flashed for 4K UHD playback/ripping using SDFtool Flasher, or is it limited strictly to standard Blu-ray / BDXL capabilities?
Thanks for your help and insight!
Re: Verbatim 66718
#6 Post by Billycar11 » Fri Aug 07, 2026 10:09 am
Sure email me that drive info section see below for email
For all others there is no need to post your makemkv drive info section publicly just email it to me directly
Re: Verbatim 66718
#7 Post by Coopervid » Sun Aug 09, 2026 8:57 am
salamdiab wrote: Fri Aug 07, 2026 9:47 am Hi everyone,
OS device name: E:
Revision: 1.00
This drive can't be flashed for UHD.
