DJRumpy wrote:Confirmed for UPN 31398244110, MPLS 573 is the correct one.
Thanks. Trying it now and will confirm when I view it later
My copy is also the unrated version and all the segment maps start with 517.DJRumpy wrote:Confirmed for UPN 31398244110, MPLS 573 is the correct one.
I'm just here to confirm that mpls 573 worked for me.FatLibertarianDude wrote:My copy is also the unrated version and all the segment maps start with 517.DJRumpy wrote:Confirmed for UPN 31398244110, MPLS 573 is the correct one.
I will give 573 a try and then report back if it worked for me.
How do you determine which title is "Playlist 573"?SeaLight wrote:573 worked for me too for the unrated version. Thanks!
I know I'm 10 years late replying to this topic, but thank you so much. I couldn't even get the disc to play on my PC in order to use Process Monitor to figure out the correct mpls, and I see others weren't getting the correct results with that anyway. I have the same sku as you. So I'm going with 573 as you suggested.DJRumpy wrote: Thu May 19, 2016 11:51 pm Confirmed for UPN 31398244110, MPLS 573 is the correct one.
