Need firmware for flashing BD-RW BDR-212M
diron
Post by diron »
Hi, I am new to the forum but have been using MakeMKV with a different drive for a while. I just bought a BD-RW BDR-212M from Japan, it works fine but the firmware seems to not be compatible with UHD. I think it can be flashed so I was hoping I could get the necessary files for this model from this forum :)
I don't know if I should post the whole MakeMKV output for the drive model and firmware. I think these are the relevant ones: Kernel Type: ID56 / Hardware Rev: SAT 8F00
If more info is needed, tell me and I can post it. Thanks in advance.
Re: Need firmware for flashing BD-RW BDR-212M
Sure just email me your makmkv drive info section see below for email
diron wrote: Thu Aug 06, 2026 2:38 pm Hi, I am new to the forum but have been using MakeMKV with a different drive for a while. I just bought a BD-RW BDR-212M from Japan, it works fine but the firmware seems to not be compatible with UHD. I think it can be flashed so I was hoping I could get the necessary files for this model from this forum :)
Please post your Makemkv info with the firmware date.
Hucz89
Post by Hucz89 »
Coopervid wrote: Thu Aug 06, 2026 7:59 pm
Manufacturer: PIONEER
Product: BD-RW BDR-212BK
Revision: 1.04
Serial number: <redacted>
Firmware date: 2022-12-20
Firmware version: ID81
Hucz89 wrote: Mon Aug 10, 2026 3:43 am
Revision: 1.04
Only Billy can help you as this firmware is too new for the flasher.
