Need firmware for flashing BD-RW BDR-212M
diron
#1 Post by diron » Thu Aug 06, 2026 2:38 pm
Hi, I am new to the forum but have been using MakeMKV with a different drive for a while. I just bought a BD-RW BDR-212M from Japan, it works fine but the firmware seems to not be compatible with UHD. I think it can be flashed so I was hoping I could get the necessary files for this model from this forum :)
I don't know if I should post the whole MakeMKV output for the drive model and firmware. I think these are the relevant ones: Kernel Type: ID56 / Hardware Rev: SAT 8F00
If more info is needed, tell me and I can post it. Thanks in advance.
Re: Need firmware for flashing BD-RW BDR-212M
#2 Post by Billycar11 » Thu Aug 06, 2026 2:53 pm
Sure just email me your makmkv drive info section see below for email
#3 Post by Coopervid » Thu Aug 06, 2026 7:59 pm
diron wrote: Thu Aug 06, 2026 2:38 pm Hi, I am new to the forum but have been using MakeMKV with a different drive for a while. I just bought a BD-RW BDR-212M from Japan, it works fine but the firmware seems to not be compatible with UHD. I think it can be flashed so I was hoping I could get the necessary files for this model from this forum :)
Please post your Makemkv info with the firmware date.
Hucz89
#4 Post by Hucz89 » Mon Aug 10, 2026 3:43 am
Coopervid wrote: Thu Aug 06, 2026 7:59 pm
Manufacturer: PIONEER
Product: BD-RW BDR-212BK
Revision: 1.04
Serial number: <redacted>
Firmware date: 2022-12-20
Firmware version: ID81
#5 Post by Coopervid » Mon Aug 10, 2026 8:08 pm
Hucz89 wrote: Mon Aug 10, 2026 3:43 am
Revision: 1.04
Only Billy can help you as this firmware is too new for the flasher.
timk22
#6 Post by timk22 » Thu Aug 13, 2026 10:38 am
I have a BDR-212M with the info as follows:
Product: BD-RW BDR-212M
Revision: 1.01
Firmware date: 2020-07-21
Drive platform: RS8F00
Firmware version: 1.01/ID56
I believe this can be flashed to read UHD BD as it has the old firmware on it, is this correct?
#7 Post by Coopervid » Mon Aug 17, 2026 7:50 pm
timk22 wrote: Thu Aug 13, 2026 10:38 am Hi,
Revision: 1.01
PM sent.
#8 Post by Billycar11 » Mon Aug 17, 2026 9:47 pm
Revision: 1.01
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
