Verbatim Ultra HD 4K External slimline Blu-ray Writer -Can/should i Flash the drive?
Hoggorm
Post by Hoggorm » Wed Aug 05, 2026 7:03 pm
I have this Verbatim Ultra HD 4K External slimline Blu-ray Writer and I get a couple of error messages when I try to rip a UHD demo disk:
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0' Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0' Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
I can rip regular Blu-ray discs though.
Reading the forum, and asking chatGPT, there seems a way to flash the drive so that it will allow UHD ripping? I do not find Verbatim brand in the list though. Can i follow the instructions in the forum post: Ultimate UHD Drives Flashing Guide Updated 2026?
I have never done this before and fear destroying the drive altogether should I do something wrong...
This is what MakeMKV display:
Product: BD-RE BU40N
Revision: 1.05
Serial number: MO7P9QE5252
Highest AACS version: 81
Disc Information
Label: DTS_UHD_Demo_3
Timestamp: 2017-12-11 13:58:34
Protection: AACS2.0/C v61
Data capacity: 33.36 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Does this drive look like a good candidate for flashing to UHD-friendly firmware, and if so, which firmware would you recommend?
Thanks in advance!
yu-yevon
Re: Verbatim Ultra HD 4K External slimline Blu-ray Writer -Can/should i Flash the drive?
Post by yu-yevon » Thu Aug 06, 2026 12:48 am
You can flash it with firmware BU40N 1.03MK
Hoggorm
Post by Hoggorm » Thu Aug 06, 2026 10:16 am
yu-yevon wrote: Thu Aug 06, 2026 12:48 am You can flash it with firmware BU40N 1.03MK
Thank you.
I was able to flash the drive and it worked perfectly after restarting the computer
