Is this drive compatible with custom firmware
XG_KM
#1 Post by XG_KM » Thu Aug 06, 2026 4:46 am
I needed an external Blu-Ray drive for a project so I just grabbed an inexpensive drive off Amazon and I decided since the project was over I would look into flashing this drive. It had a strange looking identification in MakeMKV so I took it out of its case and it had the attached label.
The drive had a mini-B USB to SATA adapter attached I also attached USB-A to SATA adapter and this is what MakeMKV identifies it as the following:
___________________________________
External Case
USB Mini-B to SATA
Manufacturer: Generic
Product: External
Revision: GE03
Serial number: KZ1IC3G5055
Firmware date: 2118-01-22 14:36
Bus encryption flags: 1F
Highest AACS version: 76
USB to Slimline SATA adapter
Manufacturer: 000000
Product: 9999999999999999
Revision: GE03
Highest AACS version: 82
Is this capable of being flashed? Thanks in advance for any help on this.
KM
Edit: it looks like my attachment did not upload but the drive has the following printed on the label:
UHD Blu-ray / DVD writer LN P/N: SDX0K84159 FRU P/N: 45K0497 REV: 102
Model : BU50N
(AL0K133)
December 2018
F/W: GE03
MSIP-REM-HLD-BU40N
Re: Is this drive compatible with custom firmware
#2 Post by MartyMcNuts » Thu Aug 06, 2026 4:53 am
XG_KM wrote: Thu Aug 06, 2026 4:46 am I needed an external Blu-Ray drive for a project so I just grabbed an inexpensive drive off Amazon and I decided since the project was over I would look into flashing this drive. It had a strange looking identification in MakeMKV so I took it out of its case and it had the attached label.
External Case
USB Mini-B to SATA
Product: External
Revision: GE03
Revision: GE03
KM
Whatever adapter you are using does not pass through the required information. Use one of the recommended adapters from the Ultimate UHD Drive guide 2026 then post the text from the drive info and libredrive info sections.
You cannot attach images/files.
XG_KM
#3 Post by XG_KM » Thu Aug 06, 2026 4:59 am
I edited the post to give some more info and I used the following adapter.
https://www.amazon.com/dp/B073VJT6C6?re ... title&th=1
chenyang CY USB 3.0 to 7+6 13Pin Slimline SATA Cable Adapter for Laptop CD DVD ROM Optical Drive
I think this was on the recommended list.
#4 Post by Billycar11 » Thu Aug 06, 2026 5:13 am
XG_KM wrote: Thu Aug 06, 2026 4:59 am I edited the post to give some more info and I used the following adapter.
that 100% is not on the recommended list
XG_KM
#5 Post by XG_KM » Thu Aug 06, 2026 5:21 am
Billycar11 wrote: Thu Aug 06, 2026 5:13 am
Here's the list I found it on.
List below is for past refence and if it becomes relevant in the future for now any USB devices that works with optical drives should be able to flash them:
USB enclosures/sata adapters that work with optical drives and flashing:
OWC Mercury Pro 5.25 case https://www.amazon.com/dp/B06XRCCV44?th=1
Pioneer 5.25 drives stick out a bit without modification but is still the recommended case overall @Coopervid for Tab modification Pic https://mega.nz/file/mV5mCDhT#T794dO696 ... l_wcIH352A
Silverstone TS14 slimsata 9.5mm to USB-Marty eject button does not work use software to eject
ICY BOX IB-550StU3S 5.25 case-ddeconin
Alxum AX-SC021NEW USB to sata cable-Marty
BENFEI SATA to USB 3.0 Cable, USB 3.0 to SATA III with 12V/2A-Coopervid https://www.amazon.com/Benfei-Adapter-C ... T17B8?th=1
Sata to Slim Sata Adapter https://www.amazon.com/ChenYang-slimlin ... 18-7067709
5.25 bay to 9.5mm adapter useful for using BU40N with OWC case https://www.newegg.com/icy-dock-mb343sp ... -_-Product
I clicked the link for the SATA to Slim SATA adapter and the adapter I bought is what showed on Amazon. Amazon must have updated the link or something. I may try connecting this to direct SATA on my desktop when I get a chance.
Thanks for the response.
KM
#6 Post by MartyMcNuts » Thu Aug 06, 2026 6:02 am
External Case
USB Mini-B to SATA
Product: External
Revision: GE03
Revision: GE03
KM
Model : BU50N
(AL0K133)
December 2018
F/W: GE03
MSIP-REM-HLD-BU40N
Ok, so being a BU50N, once you get a proper adapter that passes through info correctly, you will be able to flash it to BU40N 1.00 directly as it does not contain encrypted firmware.
#7 Post by Billycar11 » Thu Aug 06, 2026 7:53 am
XG_KM wrote: Thu Aug 06, 2026 5:21 am
KM
its not on that list you clicked a different option once you were on the page only the option it went to is the correct one
