Kill Bill: The Whole Bloody Affair UHD rip not progressing
Tok72
Re: Kill Bill: The Whole Bloody Affair UHD rip not progressing
Post by Tok72 » Mon Aug 03, 2026 7:09 pm
nullunit wrote: Tue Jul 28, 2026 9:00 pm There is an issue when MakeMKV tries to interleave the BL and EL hevc streams for these "Lionsgate 2298 frame RPU" discs. With info from chalaheadchala's posts, I am using this work around for the time being:
1. Use MakeMKV to backup the disc Decrypted
2. Use ffmpeg, dovi_tool, and mkvmerge to create a MKV with DoVi information intact.
The issue might be related to this warning I get from ffprobe at the 1m31s mark:
[in#0 @ 0x2a4e1f40] Invalid Block Addition value 0x0 for unknown Block Addition Mapping type 68766345, name "Dolby Vision enhancement-layer HEVC configuration"
[in#0 @ 0x2a4e1f40] Unsupported encoding type
MakeMKV could be getting tripped up by this during the BL and EL interleaving.
So are the steps detailed above avoiding the error that makeMKV encounters when doing a straight rip and keeping the DV Profile 7 intact?
Another title with a similar issue was Lionsgate's UHD of The Ninth Gate. I ended up remuxing to use DV Profile 8. When I did a straight rip of that title it would fail but I was able to do a backup and then rip it, but playing back the rip from that method caused my players' video output to go blank with in the first couple of minutes of the movie. I ended up remuxing that rip to use DV Profile 8, but I'm assuming I lost the FEL data.
I was able to successfully rip KBTWHBA with your method and I watched the first few minutes last night with no video dropping.
rkhollister
Post by rkhollister » Tue Aug 04, 2026 10:13 am
So what worked for me on disc 2 was making a decrypted backup using MakeMKV and then creating the MKV from that backup using MKVToolNIX (GUI v100 on a Mac). Trying to use MakeMKV on the backup copy just stalled at the exact same place as attempting to rip the disc directly.
I had the same issue with the recent Lionsgate "The Arrival". I did NOT have this issue with "The Ninth Gate" copy I have.
I also successfully appended the two MKV's using MKVToolNIX
nullunit
Post by nullunit » Tue Aug 04, 2026 2:06 pm
Tok72 wrote: Mon Aug 03, 2026 7:09 pm
That is correct. The steps avoid using MakeMKV's BL & EL interleaver and uses dovi_tool interleaver instead (keeping the DV Profile 7 intact). The resulting mkv is what MakeMKV ideally would have produced; minus adding extracted DTS core audio tracks or adding force subtitle tracks (if any detected by MakeMKV). This workaround should work for any of these troublesome Lionsgate 2298 RPU frame releases.
james gilicuty
Post by james gilicuty » Wed Aug 05, 2026 6:26 pm
dump file for kill bill whole bloody afair
rhett7660
Post by rhett7660 » Fri Aug 07, 2026 1:37 pm
sgavette@cox.net wrote: Fri Jul 31, 2026 3:19 am
rhett7660 wrote: Thu Jul 30, 2026 12:58 pm
sgavette@cox.net wrote: Tue Jul 28, 2026 8:40 pm Neither one of my UHDs will rip, Disc 1 stops @ 654.1MB, Disc 2 @ 937.5MB. Read through some of this thread, see no resolution. Did I miss it?
Did you try the backup method first and then rip from the backup? That seems to be working for some folks.
Both with and without Decrypt on. I only tried disc 1, did not work either way, still stalls at exactly same place as ripping disc, 654MB
Edit: Just tried Disc 2, same.
On both disc's it would stick, but then in a minute or two it would move forward. I was able to successfully rip both discs this way. I would give a few minutes and see if that helps. I did find, that if you backup to an SSD and then rip to a second SSD, it the rip goes really fast... I mean really fast!!!
Tok72
Post by Tok72 » Sat Aug 08, 2026 8:25 am
nullunit wrote: Tue Aug 04, 2026 2:06 pm
Thank you. Used this method to create a proper rip of the Ninth Gate as well. Though I had to map each audio track individually because the PCM track was causing problems but I finally figured it out.
