Hello everyone,
I'm having a strange issue with the German 4K UHD Steelbook release of How to Train Your Dragon (2025) from Universal.
Drive:
HL-DT-ST BD-RE BU40N
Firmware: 1.00 (Original, unpatched)
LibreDrive: Enabled
MakeMKV: 1.18.4
Problem:
The UHD disc is not detected at all.
Windows Explorer does not recognize that a disc is inserted.
MakeMKV reports "No disc inserted".
The drive information shows "No disc inserted".
However:
The included Blu-ray from the same Steelbook is detected immediately and can be opened normally in MakeMKV.
Other UHD discs (for example The Lord of the Rings) are detected and ripped without any problems.
The same UHD disc plays perfectly in my standalone 4K UHD Blu-ray player connected to my TV.
So the issue only occurs with this specific UHD disc in my BU40N.
Has anyone experienced the same problem with this release?
Is this a known compatibility issue with this particular Universal pressing, or could it indicate a problem with my drive?
Any help would be greatly appreciated.
Thank you!
German Universal UHD "How to Train Your Dragon (2025)" not detected by BU40N (Firmware 1.00)
DarkTerminator
Nico_coiN
Re: German Universal UHD "How to Train Your Dragon (2025)" not detected by BU40N (Firmware 1.00)
While I have very few experience in ripping UHD discs through MakeMKV I had the exact same issue with the Interstellar 4k Bluray: no disc detected at all and endless gritty sounds from my drive. I just followed the instructions & help I got on this forum and flashed the DE_LG_BU40N_1.03_MK.bin firmware on it. Since then, the magic operates...
More likely a bad/dirty disc. Give it a good clean before trying again. Also try a different drive if you can.DarkTerminator wrote: Wed Aug 05, 2026 3:44 pm Hello everyone,
Drive:
LibreDrive: Enabled
MakeMKV: 1.18.4
Problem:
However:
Thank you!
