Flashing BU40N : almost there, yet need help
Theozefrench
#1 Post by Theozefrench » Wed Aug 05, 2026 10:07 am
Hi there,
After my previous BU40N flashed years ago died during the heatwave, I bought another one and am trying to flash it.
I'm on MacOS, using terminal and following the instructions from this post : viewtopic.php?t=19634
MakeMKV when launched displays this information :
Product: BD-RE BU40N
Revision: 1.05
Serial number: MOBQ3AI2134
Highest AACS version: 81
After copying the SDF.BIN and the firmware file to /tmp I run the flash command and gets this in return :
./makemkvcon f -d '/IOBDServices/CCAE52B9' -f /tmp/sdf.bin rawflash main -i '/tmp/DE_LG BU40N_1.00.bin'
Reading input file /tmp/DE_LG BU40N_1.00.bin
Current Drive ID: HL-DT-ST_BD-RE_BU40N_1.05_212404231347_MOBQ3AI2134
yes
100% Operation finished
Done successfully
Yet relaunching MakeMKV doesn't show any difference.
I have tried with MakeMKV 1.17.7 and 1.18.3, and with both firmwares HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934 and DE_LG BU40N_1.00.bin, with the same result each time.
The drive still mounts a dvd.
There has to be something I do wrong but I can't find it.
Any help from you guys would be much appreciated, thanks in advance.
Re: Flashing BU40N : almost there, yet need help
#2 Post by MartyMcNuts » Wed Aug 05, 2026 10:15 am
Theozefrench wrote: Wed Aug 05, 2026 10:07 am Hi there,
Revision: 1.05
yes
Done successfully
You need 2 flashes as this has encrypted firmware.
First flash should be to HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934 using rawflash enc.
Second flash should be to DE_LG BU40N_1.00 using rawflash main.
Sayaka
#3 Post by Sayaka » Wed Aug 05, 2026 11:06 am
(I know this is off-topic, but after this, you can upgrade to 1.18.4 here if you so wish : https://mega.nz/file/ziggWLhY#ZTkE4X3tp ... JabD6mc5Ek)
Theozefrench
#4 Post by Theozefrench » Wed Aug 05, 2026 11:13 am
THANK YOU !
Revision: 1.00
Firmware date: 2116-12-20 15:28
Firmware version: 1.00
Theozefrench
#5 Post by Theozefrench » Wed Aug 05, 2026 11:15 am
Sayaka wrote: Wed Aug 05, 2026 11:06 am (I know this is off-topic, but after this, you can upgrade to 1.18.4 here if you so wish : https://mega.nz/file/ziggWLhY#ZTkE4X3tp ... JabD6mc5Ek)
Will do, thanks !
Theozefrench
#6 Post by Theozefrench » Thu Aug 06, 2026 6:56 am
@MartyMcNuts thanks again, it works like a charm.
Now to educate me so next time I don't have to be a burden, can you point me to a post listing the different firmwares and wether they are encrypted or not ? I got lost there.
Thanks again
#7 Post by MartyMcNuts » Thu Aug 06, 2026 7:40 am
Theozefrench wrote: Thu Aug 06, 2026 6:56 am @MartyMcNuts thanks again, it works like a charm.
Thanks again
Firmware dated from 2020 are encrypted. Earlier firmware is not.
