The Friends 25th Anniversary Complete Series DVDs take 20–30 minutes to analyze. Both an Apple SuperDrive and an ASUS drive behave identically. Rips succeed, but analysis pauses for minutes while processing empty audio streams. So the scan and tip each take roughly 30 minutes. Any work arounds for a novice?
we are at 23minutes and counting - the time remaining is climbing but currently at 10min
Title #1 was added (37 cell(s), 3:27:59)
Title #2 was added (5 cell(s), 0:22:11)
Title #3 was added (5 cell(s), 0:22:34)
Title #4 was added (5 cell(s), 0:24:16)
Title #5 was added (5 cell(s), 0:23:15)
Title #6 was added (5 cell(s), 0:22:33)
Title #7 was added (5 cell(s), 0:22:28)
Title #8 was added (5 cell(s), 0:22:20)
Title #9 was added (5 cell(s), 0:24:28)
Title #10 was added (5 cell(s), 0:24:02)
Title #11 was added (2 cell(s), 0:02:11)
Title #12 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Audio stream #1 in title #1 looks empty and was skipped
Audio stream #1 in title #2 looks empty and was skipped
Audio stream #1 in title #3 looks empty and was skipped
Audio stream #1 in title #4 looks empty and was skipped
Audio stream #1 in title #6 looks empty and was skipped
Audio stream #1 in title #7 looks empty and was skipped
Audio stream #1 in title #8 looks empty and was skipped
Long Scan
Re: Long Scan
What happens if you make a decrypted backup of the disc (the icon of the yellow folder and the green arrow on the first screen of MakeMKV) and then open the backup and create .mkv files from the backup?
