BH16NS55 1.02 was one of the original drive firmwares that are UHD friendly out of the box. My first UHD capable drive was a BH16NS55 on it's original v1.02 firmware purchased at the end of 2017! I still have that drive too (along with an original WH16NS60), just put away as I now only use my Pioneer drives.Sayaka wrote: Tue Aug 04, 2026 11:51 pmIt would appear that I was being a colossally absent-minded person by forgetting to check the latest LibreDrive compatibility list. Thank you, and my apologies.It doesn't need flashing. It is UHD compatible as is. The only reason to flash it, would be to remove the sleep bug, which isn't really necessary anyway. If you want to flash it, use WH16NS60 1.02-MK.
Re: SDFtool Flasher
Sayaka
Re: SDFtool Flasher
I said "latest LibreDrive list" not because I believed support was recently added, but simply because I forgot to check the list altogether.
I added "latest" just as a way of wording it.
...Not to mention, I read a lot and am usually pretty good at finding the right information, and I've seen a decent amount of optical drives in my life, but I have less experience than people who have probably "worked" on 100+ drives. I also probably wouldn't be able to fully memorize that LibreDrive list.
ionas
Re: SDFtool Flasher
No apologies necessary. I did not know eitherSayaka wrote: Tue Aug 04, 2026 11:51 pmIt would appear that I was being a colossally absent-minded person by forgetting to check the latest LibreDrive compatibility list. Thank you, and my apologies.It doesn't need flashing. It is UHD compatible as is. The only reason to flash it, would be to remove the sleep bug, which isn't really necessary anyway. If you want to flash it, use WH16NS60 1.02-MK.
Thank you i'll give it a try as is
JeremyTheGreat2
Re: SDFtool Flasher
Thank you! This made it really easy to get my drive to recognize 4k discs
adamtg
Re: SDFtool Flasher
I was able to successfully flash my drive (BU40N) to 1.03MK and everything works. However, I received an error at the end, but I clicked too quickly and did not save it, and the Firmware_Dumps were not created. If I need to revert to 1.05 for any reason, should I just reflash using the official files from the LG website?
Sayaka
Re: SDFtool Flasher
You could, but please be aware that several people have had issues with those official LG flashers.
You will also be unable to extract the 1.05 firmware from the official LG flasher (it won't work if you do a firmware dump of a BU40N with 1.05 firmware, either) : the 1.05 firmware is encrypted.
adamtg
Re: SDFtool Flasher
That's not good to hear. Well, I'll worry about that if I need to send the drive in for a warranty repair. Fingers crossed I won't have to.Sayaka wrote: Fri Aug 21, 2026 2:44 pm You could, but please be aware that several people have had issues with those official LG flashers.
RibShark
Re: SDFtool Flasher
https://workupload.com/file/pvw2FG6GarFSayaka wrote: Fri Aug 21, 2026 2:44 pm You could, but please be aware that several people have had issues with those official LG flashers.
Sayaka
Re: SDFtool Flasher
Wow, that's... impressive. Thank you.
RibShark
Re: SDFtool Flasher
Is there any reason RECOVER flashes use the nowait parameter? It shouldn't be required and I've had a few people come to me with failed flashes because they disconnected their drive before it was done since nowait doesn't wait for it to be finished.
Re: SDFtool Flasher
because thats how mike showed it to use i use it that way too in my cli auto flashersRibShark wrote: Sat Aug 29, 2026 9:13 am Is there any reason RECOVER flashes use the nowait parameter? It shouldn't be required and I've had a few people come to me with failed flashes because they disconnected their drive before it was done since nowait doesn't wait for it to be finished.
kinda just do as we are shown and keep it if it works
mindnomad
Re: SDFtool Flasher
I just got a BU40N and tried flashing it. seems to have done it properly but makemkv is still not reading any UHD discs i put into it. did I miss something?
Sayaka
Re: SDFtool Flasher
Could you please copy your Drive Information and LibreDrive Information in MakeMKV and post it here ? (feel free to omit the serial number part if you wish)mindnomad wrote: Sun Aug 30, 2026 1:19 am I just got a BU40N and tried flashing it. seems to have done it properly but makemkv is still not reading any UHD discs i put into it. did I miss something?
mindnomad
Re: SDFtool Flasher
i may have figured it out. but for a while it was telling me that it was patched but whenever i put in backrooms or mario galaxy 4K discs, the disc would stop spinning, it'd tell me no errors at all, and say there's no disc. i think the problem was there wasn't enough power going into the drive maybe
Re: SDFtool Flasher
Only use ports direct from the motherboard (not case ports) or an AC self-powered USB hub of at least 24w.mindnomad wrote: Sun Aug 30, 2026 8:52 pm i may have figured it out. but for a while it was telling me that it was patched but whenever i put in backrooms or mario galaxy 4K discs, the disc would stop spinning, it'd tell me no errors at all, and say there's no disc. i think the problem was there wasn't enough power going into the drive maybe
Also, insert the UHD disc and let the OS initialise it before opening up MakeMKV.
