The main track fails. Log attached (sorry about double upload - one didn't seem to work). Any advice as to settings I can try or is MakeMKV failing?
I successfully ripped it using DVDFab so the disc is fine.
I have been successful with other DVDs (terrific program BTW).
thanks
Bruce
DarkCity - Copy complete. 2 titles saved, 1 failed.
- MakeMKV_log.txt
- (473.75 KiB) Downloaded 458 times
- Contact:
Re: DarkCity - Copy complete. 2 titles saved, 1 failed.
This looks like a bug in MakeMKV. In order to properly troubleshoot it, I have to ask you to do a lengthy step - please submit a test dump for the main title per instructions at http://www.makemkv.com/onlinehelp/testdump.html .
Hi Mike
Tried this when only selecting the failing track. I tried the *TESTDUMP* setting
immediately after loading MakeMKV and, after reloading the program, after
loading the DVD but just before pressing the Make MKV button. No difference.
Used administration mode (Win7).
No file is produced at all. Attached the log.
When I tried with all tracks, I got title01.tgz and title02.tgz. No title00.tgz which
is the track with the problem.
I am using 1.7.4 Beta.
thanks
thanks
- MakeMKV_log.txt
- (22.66 KiB) Downloaded 506 times
