Public KeyDB Disc Submissions
ei4kn
Post by ei4kn »
Dabruce
Post by Dabruce »
Disc type: UHD
Disc ID: 0x87EA2DD7B65A91DDBCB937B2E96537E4ADFE5BE6
Disc dump filename: MKB20_v82_MORTAL_KOMBAT_II_CA32
Drive: BW16D1HT
Drive firmware: 3.10
LibreDrive status: Enabled
Disc dump link: https://drive.google.com/file/d/1dTTHG6 ... sp=sharing
MKB_RO.inf Link: https://drive.google.com/file/d/1iIZrSq ... sp=sharing
thank you
keydb_helper
Post by keydb_helper »
Dabruce wrote: Tue Aug 04, 2026 1:03 pm Disc type: UHD
Thanks for following the submission template Dabruce. Your disc has been added to the public keydb.
keydb_helper
ei4kn wrote: Tue Aug 04, 2026 10:45 am Joan of Arc 4K
Thanks for the new disc dump ei4kn. Your disc (MKB20_v82_JOAN_OF_ARC_48F0) has also been added to the public keydb.
fidgettcat
Post by fidgettcat »
Disc type: UHD
Disc ID: A9A2E075EADC9D8B6A6E909F0A378B282BB47DA8
Disc dump filename: MKB20_v82_ONCE_A_THIEF_UHD_C9FA
Drive: BD-RE WH16NS60
Drive firmware: 1.02
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://www.mediafire.com/file/efs02bbd ... O.inf/file
Disc dump link: https://www.mediafire.com/file/qma5xlpx ... A.tgz/file
keydb_helper
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
MKB20_v82_King_Creole (0x8C7DBCB3E2EADF61BB2A74012E1E37668CD7DB99)
MKB20_v82_LittleFockers_UPK75 (0x741052491F1CF1C2FEB55678F5E285045C55A346)
MKB20_v82_THE_PEOPLE_VS_LARRY_FLYNT (0x2CE70C45A09B0BB421DD19698DDB9D03C2BF32EF)
