Submitted
Stranger Things UHD
Re: Stranger Things UHD
Huzzah! Knew it would be something along these lines
Submitted
Submitted
Using: ASUS BW-16D1HT 3.00
Guys what size dose the complete sessions end up being. Need to work out hdd space.
Thank you for any help
SimplyLearning
Been going through my box set and cannot rip Season 2 Disc 2, I keep getting a decryption error. Any ideas why this is happening on just this disc? With the exception of this disc I have thus far successfully ripped all of Season 1, all other discs from Season 2 and all of Season 3. Have yet to start Seasons 4 and 5.
I used ImgBurn to successfully create an iso from the Season 2 disc 2 and then tried MakeMKV on that iso but no luck trying that work around.
Suggestions?
My version is v1.18.3 for Windows. Using a Pioneer BDR-XS07U
Suggestions?
subzeroevil
Same here season 2 disk 2. for new release collection.SimplyLearning wrote: Mon Aug 03, 2026 4:43 am Been going through my box set and cannot rip Season 2 Disc 2, I keep getting a decryption error. Any ideas why this is happening on just this disc? With the exception of this disc I have thus far successfully ripped all of Season 1, all other discs from Season 2 and all of Season 3. Have yet to start Seasons 4 and 5.
Suggestions?
its not just you.
SimplyLearning
I just encountered a 2nd disc with the same issue, Season Four - Disc 15 - Chapters Five & Six.
Backup Failed
Backup Failed
Yes, they're not encrypted. This has been established in several threads already. Backup to folder, delete the AACS directory, and it'll open just fine in MakeMKV.
(This is only true for certain discs)
I am having the same issue with Season 2 Disk 6, Season 4 Disk 3, Season 5 Disk 21.
All other disks were fine. Sent Dump Files to support, but as of yet, no movement. It seems to stick at some the 000x.m2ts files then gives up with this error message.
Is it a manufacturing issue, disk issue, or decryption key issue?
I have tried 3 different LG Drives, and 2 different Pioneer Drives.
Thanks.
Thanks.
SimplyLearning
Thanks for the reply. Interesting. So are you saying to literally copy the contents from the disc to hard drive, say with Windows File Explorer and essentially ignore/do not copy the AACS directory then point MakeMKV to that copied folder structure?SamuriHL wrote: Mon Aug 03, 2026 3:59 pm Yes, they're not encrypted. This has been established in several threads already. Backup to folder, delete the AACS directory, and it'll open just fine in MakeMKV.
Sure or use the MakeMKV Backup function and make sure it's set NOT to decrypt. Then just delete/rename the AACS directory on the folder backup. That's a better way to do it as it does error checking while copying.SimplyLearning wrote: Mon Aug 03, 2026 5:56 pm
SimplyLearning
OK, thanks.SamuriHL wrote: Mon Aug 03, 2026 7:39 pmSure or use the MakeMKV Backup function and make sure it's set NOT to decrypt. Then just delete/rename the AACS directory on the folder backup. That's a better way to do it as it does error checking while copying.SimplyLearning wrote: Mon Aug 03, 2026 5:56 pm
As I wasn't sure of the best method, while waiting, rather than do a File Explorer copy (as using MakeMKV and not choosing to decrypt didn't even occur to me) what I had done was take my ISO that I created yesterday for my Season 2 disc using IMGBurn then mounted it, copied just the Certificate and BDMV folders out then created another a fresh ISO from that then used MakeMKV to do the rip and it worked just fine.
I'll simply use MakeMKV without decrypting for my Season 4 disc as you describe, fewer steps and more straight forward.
Thanks again.
When I get a minute I need to test those discs with my KeyDB Assistant. In theory, it should detect that they're not AACS encrypted and warn you when you do a Disc Info function. I haven't yet ripped my set but will be doing so this week and when I get to those discs I'll see if the detection works.
SimplyLearning
I encountered a 3rd disc with the same issue, Season 5 - Disc 21 - Chapters Two and Three
I've encountered the same issue with the same discs. I've been checking daily for a fix to this issue and have submitted my dumps. Its been a week now since I submitted them, so they must be quite troublesome to obtain.
keydb_helper
It turns out skipping encryption is a surprisingly effective form of DRM...
Everyone else has performed some variant of the same 'manual backup and delete the AACS folder before processing with MakeMKV' workaround. If this issue is ever resolved, it will require a MakeMKV update to avoid tripping up on unencrypted discs.
The keys for the unencrypted discs are known but they don't really serve a purpose.Lozin8019 wrote: Fri Aug 07, 2026 11:17 pm I've encountered the same issue with the same discs. I've been checking daily for a fix to this issue and have submitted my dumps. Its been a week now since I submitted them, so they must be quite troublesome to obtain.
Public KeyDB Disc Submissions
