Kill Bill: The Whole Bloody Affair UHD rip not progressing
Tok72
Re: Kill Bill: The Whole Bloody Affair UHD rip not progressing
Post by Tok72 » Mon Aug 03, 2026 7:09 pm
nullunit wrote: Tue Jul 28, 2026 9:00 pm There is an issue when MakeMKV tries to interleave the BL and EL hevc streams for these "Lionsgate 2298 frame RPU" discs. With info from chalaheadchala's posts, I am using this work around for the time being:
1. Use MakeMKV to backup the disc Decrypted
2. Use ffmpeg, dovi_tool, and mkvmerge to create a MKV with DoVi information intact.
The issue might be related to this warning I get from ffprobe at the 1m31s mark:
[in#0 @ 0x2a4e1f40] Invalid Block Addition value 0x0 for unknown Block Addition Mapping type 68766345, name "Dolby Vision enhancement-layer HEVC configuration"
[in#0 @ 0x2a4e1f40] Unsupported encoding type
MakeMKV could be getting tripped up by this during the BL and EL interleaving.
So are the steps detailed above avoiding the error that makeMKV encounters when doing a straight rip and keeping the DV Profile 7 intact?
Another title with a similar issue was Lionsgate's UHD of The Ninth Gate. I ended up remuxing to use DV Profile 8. When I did a straight rip of that title it would fail but I was able to do a backup and then rip it, but playing back the rip from that method caused my players' video output to go blank with in the first couple of minutes of the movie. I ended up remuxing that rip to use DV Profile 8, but I'm assuming I lost the FEL data.
I was able to successfully rip KBTWHBA with your method and I watched the first few minutes last night with no video dropping.
rkhollister
Post by rkhollister » Tue Aug 04, 2026 10:13 am
So what worked for me on disc 2 was making a decrypted backup using MakeMKV and then creating the MKV from that backup using MKVToolNIX (GUI v100 on a Mac). Trying to use MakeMKV on the backup copy just stalled at the exact same place as attempting to rip the disc directly.
I had the same issue with the recent Lionsgate "The Arrival". I did NOT have this issue with "The Ninth Gate" copy I have.
I also successfully appended the two MKV's using MKVToolNIX
nullunit
Post by nullunit » Tue Aug 04, 2026 2:06 pm
Tok72 wrote: Mon Aug 03, 2026 7:09 pm
That is correct. The steps avoid using MakeMKV's BL & EL interleaver and uses dovi_tool interleaver instead (keeping the DV Profile 7 intact). The resulting mkv is what MakeMKV ideally would have produced; minus adding extracted DTS core audio tracks or adding force subtitle tracks (if any detected by MakeMKV). This workaround should work for any of these troublesome Lionsgate 2298 RPU frame releases.
james gilicuty
Post by james gilicuty » Wed Aug 05, 2026 6:26 pm
dump file for kill bill whole bloody afair
rhett7660
Post by rhett7660 » Fri Aug 07, 2026 1:37 pm
sgavette@cox.net wrote: Fri Jul 31, 2026 3:19 am
rhett7660 wrote: Thu Jul 30, 2026 12:58 pm
sgavette@cox.net wrote: Tue Jul 28, 2026 8:40 pm Neither one of my UHDs will rip, Disc 1 stops @ 654.1MB, Disc 2 @ 937.5MB. Read through some of this thread, see no resolution. Did I miss it?
Did you try the backup method first and then rip from the backup? That seems to be working for some folks.
Both with and without Decrypt on. I only tried disc 1, did not work either way, still stalls at exactly same place as ripping disc, 654MB
Edit: Just tried Disc 2, same.
On both disc's it would stick, but then in a minute or two it would move forward. I was able to successfully rip both discs this way. I would give a few minutes and see if that helps. I did find, that if you backup to an SSD and then rip to a second SSD, it the rip goes really fast... I mean really fast!!!
Tok72
Post by Tok72 » Sat Aug 08, 2026 8:25 am
nullunit wrote: Tue Aug 04, 2026 2:06 pm
Thank you. Used this method to create a proper rip of the Ninth Gate as well. Though I had to map each audio track individually because the PCM track was causing problems but I finally figured it out.
tngiloy
Post by tngiloy » Mon Aug 10, 2026 6:27 pm
I'm kind of new to MakeMKV as a movie ripping tool -just ripped my BR and UHD discs to play on a Dune Duo Movie 8K- and had the same problem as many on this thread have had with KB-THBA. It just stuck shortly after starting. I tried the 'BACK-UP' and then rip that file, which worked for getting DV, but it didn't include the chapter separations. OK, but not what I need.
So I went to the MakeMKV website to make sure I had the latest fw yesterday and it was down. Also down today.
Does Make MKV shut down temporarily when updating their fw or is something else going on??
aaronwt
Post by aaronwt » Mon Aug 10, 2026 9:28 pm
SamuriHL wrote: Mon Aug 03, 2026 12:20 am Doesn't that mean you've lost the Dolby Vision FEL layer, however?
Yes. Nothing I have can play that actual layer from an MKV anyway. The TVs show they are playing Dolby Vision, but they aren't actually playing the FEL layer.
Besides, I still have the ISOs of the rips, from Xreveal. So, I can always go back to it if I ever need to. And run MakeMKV on it.
The MKVToolNix file, created from the two MKV rips, still looked great in HDR10.
63TB unRAID1-49TB unRAID2-76TB unRAID3-56TB unRAID4-24TB unRAID5-50TB unRAID6-56TB unRAID7-60TB unRAID8-60TB unRAID9
Post by SamuriHL » Mon Aug 10, 2026 9:53 pm
aaronwt wrote: Mon Aug 10, 2026 9:28 pm Yes. Nothing I have can play that actual layer from an MKV anyway. The TVs show they are playing Dolby Vision, but they aren't actually playing the FEL layer.
The only real downside is for titles that do FEL brightness expansion. Of course, if you need the trims for tone mapping on a display that's lower NIT than the content, then you lose that, too. But on a relatively high NIT display it's not a big loss these days. And this is not a super high NIT title.
cap33444
Post by cap33444 » Mon Aug 17, 2026 10:22 pm
Could you PLEASE give a bit of help on the commands for using ffmpeg and dovi_tool assuming there are two folders:Part1 and Part2 that have been made with MakeMKV Backup (Decrpt on)?? I assume that will generate two files (mkvs?) for mkvmerge.
nullunit
Post by nullunit » Mon Aug 17, 2026 11:33 pm
The commands I used for my Disc 1 are in this earlier post:
viewtopic.php?p=203106#p203106
Disc 2 is basically the same except for source folder and resulting MKV names.
cap33444
Post by cap33444 » Tue Aug 18, 2026 12:03 am
nullunit wrote: Mon Aug 17, 2026 11:33 pm The commands I used for my Disc 1 are in this earlier post:
THANKS!!!!
Mr_Orange
Post by Mr_Orange » Wed Sep 02, 2026 1:15 pm
Gosh, what a b*gger of a film this is. I had the same issues with disc 1 stopping at 650MB and disc 2 at 930MB. I'm trying the backup method, with disc 2 backed up so far. It is currently ripping after a pause at 930MB point. Hopefully, the resulting MKV is usable and then I'll give disc 1 a go and merge them with MKVToolNix.
