Hi, So long time ago I bought the program MakeMKV, i cant find that registration number. No worries I'm OK with buying a new one however it says I have to use the free one and gives me a registration code. hat doesn't work. says trial has expired. So im stuck. I cant find my old registration and it wont let me purchase a new registration and the one I'm told to use doesn't work. Can I get a fix around this, again, I dont mind paying again.
thank you
Victor
victorhopson@gmail.com, if you want to reply directly.
Need help with registration
Re: Need help with registration
Current beta key listed here is good until the end of September, so that should take care of you while you send a note to support@makemkv.com to have Mike look up your full registration key.
Yankeesfan1978
Thank you, it looks like that worked. I hope they can resolve it by Spetember. Thank you again
