Pirates of the Caribbean, The Curse of the Black Pearl
ascoop
Post by ascoop »
Recently downloaded MakeMKV and testing to back-up Blueray discs.
Experienced problem with: Pirates of the Caribbean, Curse of the Black Pearl
Program fails/crashes entirely just as it is beginning to scan the disc for titles. Error message reads, "Fatal error occurred - Program will now exit."
This disc is Clean and NEW!
Suggestions?
sixsoccer6
Re: Pirates of the Caribbean, The Curse of the Black Pearl
Post by sixsoccer6 »
Had the same problem, dunno if this is the info that can help?
Debug log started at Sat Apr 28 23:56:05 2012 , written by MakeMKV v1.7.4 darwin(x86-release)
001005:0000 MakeMKV v1.7.4 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/sixsoccer6/MakeMKV_log.txt
002010:0000 Optical drive "DVD+R-DL OPTIARC DVD RW AD-5690H 4AH5" opened in OS access mode.
002015:0000 It's highly recommended to install DASPI kernel extension to improve performance.
002010:0000 Optical drive "BD-RE TSSTcorp BDDVDW SE-506AB TS00" opened in OS access mode.
DAFD=PAAAADAAAAEABDQkEHwECAQ==
DCE=+WDoRICZqZyK0nlqr+0xro5f/jgZCt2I2gKMBezaycTjw0fCLv5EIzV3a09a64yyBNladAaSopwRhOhi854qfMAed6VbDg/fOd+f3XAlu9Po00uM5S0WTZq7VI6YS4wAEBGDsJ5v77wENVj7hUG0GXu1e26aO9lxBQ==
DCE=QnJoCNlGtZRmSfvLXtPnS4pHSGwA4b54zfhMnPM3NFwel8aTrYdvDjObQ611xTZ8RZ8o5tzBpoy9+6Mc4eRxojF/nNkStnD5SzryvzNCzpmSHiADY+5s4Sj2p77wYif+IgiyuJqIkcO3Z7TM+6ElLdSmQXvTsx92LQ==
DISCID=1596EE8FFB688FBA80F3844BF7AA2A216B4EDED8
003307:0000 File 00027.m2ts was added as title #0
003307:0000 File 00001.mpls was added as title #1
003307:0000 File 00009.mpls was added as title #2
003307:0000 File 00010.mpls was added as title #3
okeven
Post by okeven »
I am having the same problem. I sent in an error report last week. Any updates?
crowfax
Post by crowfax »
Have you installed the DASPI kernel extension? It's in the MakeMKV installer package for OSX.
okeven
Post by okeven »
I am not running OSX, so that would not apply to me.
crowfax
Post by crowfax »
Then you need to turn on debugging and post a log.
okeven
Post by okeven »
I already emailed in a log last week. I never received a response back.
crowfax
Post by crowfax »
You'll only be contacted if they need more information from you.
dmsmd
Post by dmsmd »
A temporary workaround for this disk is to set the minimum file length to something large (2400 seconds works) and that will skip the track that makemkv crashes on. After that it worked fine with 1.7.4 64-bit Linux version.
okeven
Post by okeven »
That workaround worked for me as well. Thanks!
TimRedBeard
Post by TimRedBeard »
This work around helped me as well, thanks!
TRB
Mac Setup: 2011 MBP 2.2GHz i7 - 10.7.3 - 16GB RAM / OWC 120GB SSD & 750GB 2nd Drive
Burning Setup: BR Samsung SE-506 / MakeMKV / HandBrake 0.9.6 / MKVtoolnix (For subs)
Media Setup: Jailbroken Apple TV 2 w/ XBMC / GoFlex Home 2GB NAS
JasonX
Post by JasonX »
Confirm that the 2400 second workaround also works for v1.74 on Windows. Otherwise, the .exe crashes out.
Post by mike admin »
This should been fixed in 1.7.5
