PM sent.Haldrie wrote: Thu Jul 23, 2026 8:26 pm Well seeing as how this is still going and I too have one of these drives might as well give it a shot.
Drive Information OS device name: F: Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: CIDL502556WL Firmware date: 2020-06-15 Bus encryption flags: 1B Highest AACS version: 81 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
RenegadeRaven
Thank you.Coopervid wrote: Fri Jul 31, 2026 9:20 amPM sent.RenegadeRaven wrote: Thu Jul 30, 2026 8:26 pm Hello @Coopervid,
It would be greatly appreciated if you can assist me as well.
Thanks in advance!Code: Select all
Drive Information OS device name: \Device\CdRom2 Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Firmware date: 2020-06-15 Bus encryption flags: 1B Highest AACS version: 65 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Quick question; are there instructions on how to backup the current firmware before cross-flashing, just in case I ever need to revert back?
You can‘t but I could send you UD03 firmware if you need to flash for warranty. But I guess that has expired anyway.
Hello, I just purchased one of these too. Please and thank you!
Sure email me the makemkv drive info section see belowmrdvd wrote: Fri Jul 31, 2026 6:39 pm Hello, I just purchased one of these too. Please and thank you!
OS device name: \Device\CdRom6
Revision: 1.03
Serial number: QEDL404787WL
Firmware date: 2015-05-14
Highest AACS version: 82
Drive platform: RS8510
Firmware version: 1.03/ID19
Will this work on mine too? old thread I know, sorry.
Revision: 1.03
Sure email me the makemkv drive info section see belowVital64 wrote: Sun Aug 02, 2026 7:20 pm Drive Information
Revision: 1.03
Sounds good, I will send you an email. Thank you!
PM sent.Vital64 wrote: Sun Aug 02, 2026 7:20 pm Drive Information
Revision: 1.03
