Is this revision UHD compatible? BP50NB40 NB50 (Rev 1.01, Oct 2025) - No LibreDrive Information shown in MakeMKV.
Zombiciego
I kindly request some help before attempting any firmware flashing please. I'd like to confirm whether my specific drive revision is actually supported.
My drive:
Model: LG BP50NB40
SVC: NB50
ROM: LB20
Manufactured: Oct 2025
MakeMKV 1.18.4 reports:
Manufacturer: LG
Product: BP50NB40
Revision: 1.01
Serial: WR55 407598
Highest AACS version: 68
The drive works perfectly with standard Blu-ray discs:
Windows detects them
MakeMKV reads them
Full MKV rips complete successfully
However, no LibreDrive Information section is shown at all (no Status, no Drive Platform, no Firmware Support).
I also tested with UHD discs (The Shining 4K and The Thing 4K):
Windows: no media
MakeMKV: no disc inserted
VSO Inspector: no media
Drive spins for a few seconds, attempts to focus, then stops.
My question is:
Is this BP50NB40 revision (NB50 / Rev 1.01 / LB20 / Oct 2025) compatible with the current UHD flashing procedure?
Also, is it normal that MakeMKV doesn't show the LibreDrive Information section at all on this revision?
Thank you!
My drive:
Model: LG BP50NB40
SVC: NB50
ROM: LB20
Manufacturer: LG
Product: BP50NB40
Revision: 1.01
Serial: WR55 407598
MakeMKV reads them
Windows: no media
My question is:
Thank you!
Sayaka
Re: Is this revision UHD compatible? BP50NB40 NB50 (Rev 1.01, Oct 2025) - No LibreDrive Information shown in MakeMKV.
This looks very much like a "bad" (and possibly counterfeit) drive to me, or at the very least a drive with an enclosure that's not "playing nice" with MakeMKV. Did you buy it from a Chinese seller, perchance...?
Zombiciego
Hi Sayaka, I bought it ionline from a random reseller, all the docs inside the drive box were in chinese, but other than that, the drive seems to be built with good quality... but it might be a "good" fake drive perhaps (these drives are very hard to get where I live, the only ones available are the ones from unknown brands).Sayaka wrote: Sun Jul 26, 2026 5:57 pm This looks very much like a "bad" (and possibly counterfeit) drive to me, or at the very least a drive with an enclosure that's not "playing nice" with MakeMKV. Did you buy it from a Chinese seller, perchance...?
It is this one:
https://www.mercadolibre.com.ar/lg-lect ... sid=search
There is also a Pioneer drive but it does looks fake to me... and it has almos no information so I got the LG drive. But I can return it if it´s fake and get this Pioneer instead I think...
https://www.mercadolibre.com.ar/usb-ext ... sid=search
Sayaka
Sadly, I cannot access these webpages, which merely tell me I am not registered.
The "LB20", "WR55" and the fact that there's no LibreDrive information, as well as the fact that "all the docs inside the drive box were in chinese", all combined make me think that this is indeed a counterfeit drive. You should be wary when it comes to buying from random sellers (sometimes they may even sell you a fake drive without knowing that it's a fake drive).
I would recommend returning the drive and buying this instead, if you'd like a slim drive : https://www.bhphotovideo.com/c/product/ ... e_usb.html
Expensive indeed, but at least it's guaranteed to be an LG drive and not a counterfeit drive. This website should ship to Argentina.
You could also try this if you'd like a 5.25 drive : https://www.bhphotovideo.com/c/product/ ... lu_ray.htm (it *might* turn out to be a Pioneer, but please don't get your hopes up).
Zombiciego
Hi again! Just wanted to let you know I finally pulled the trigger and ordered both Buffalo drives you recommended (I will use one for ripping and the other one just as a backup drive) so thank you for everything!Sayaka wrote: Sun Jul 26, 2026 8:41 pm Sadly, I cannot access these webpages, which merely tell me I am not registered.
Buffalo BRXL-16U3 (Desktop)
Buffalo BRXL-PUS6U3B-TAA (Portable)
They're on their way now. And I will initiate the return of the fake LG today.
While I wait for them to arrive, I'd like to prepare everything in advance. I´d appreciate any additional tips if you have experience flashing these drives please... any recommended firmware/LibreDrive flashing procedure for each model or any updated guide for them.
I'd rather do it the safest way possible and avoid briking the new drives haha
Thanks again for the recommendation!
Sayaka
Hi again,
For now I will say that the Buffalo BRXL-PUS6U3B-TAA is likely to be a BU40N with the MT1959 platform, and in that case you should flash BU40N 1.03-MK (likely with encryption), and then BU40N 1.00-DE if you wish to have DVDFab compatibility on Windows or if you have issues making 1.03-MK work on Linux (if you use Linux in addition to using Windows).
As for the BRXL-16U3, if it's a LG (likely) I believe it will likely be a BH16NS58 with the MT1959 drive platform, and in that case you should flash it to WH16NS60 1.02-MK.
If you are very lucky and the BRXL-16U3 turns out to be a Pioneer, you will likely need to wait for someone else to help you after posting the LibreDrive information (Billycar11 or possibly Coopervid should be able to help you). I know the names of some of the flashers used to flash Pioneer drives (DVRFlash, DVRTool, BDRFlash and then there's also Billycar11's flasher) but I am not experienced when it comes to using the Pioneer flashers and in fact I do not have all of them on my computer (and the same is true for the needed firmware files). Getting help from an experienced person is highly recommended when you wish to flash a Pioneer drive, as otherwise you might not even have access to the needed program/firmware files.
You're using Windows, yes ? I assume you're planning on performing the flashing operations on Windows as well ? If so, I will try to post a more detailed guide for you within the next 48 hours. Nevertheless, please do post the Drive information/LibreDrive information sections for those drives when you receive them before proceeding, please.I´d appreciate any additional tips if you have experience flashing these drives please... any recommended firmware/LibreDrive flashing procedure for each model or any updated guide for them.
Zombiciego
Sayaka wrote: Tue Jul 28, 2026 12:58 am Hi again,
Sayaka,
Thank you so much for taking the time to write such a detailed advice!
I'll be using Windows for all the flashing operations and drive use, and yes, I am also currently using PlayerFab for playback (Not sure if there is other option but I tried cyberlink and playback failed with that one), and I use MakeMKV for ripping my movies, so the firmware options are very helpful. As soon as I receive the drives, I'll post here the complete Drive Information and LibreDrive Information sections from MakeMKV for each one before attempting any firmware changes.
According to the current DHL estimate, the package should arrive on Wednesday, so there's absolutely no rush regarding the guide. Please take all the time you need!
Thanks again for all your help. I really appreciate your willingness to prepare a guide specifically for these models. I´ll provide all the info I can about them, and probably this thread might also be useful for someone else with the same drives in the future!
Sayaka
Here we go.
First, you should download this (MartyMcNuts' All You Need Firmware Pack) : https://www.mediafire.com/file/bpl3pz2b ... 9.zip/file
as well as the latest version of SDFtool Flasher : viewtopic.php?t=22896
Unzip these files.
Then, please have a look at this to get acquainted with SDFtool Flasher :
https://mega.nz/file/TyQzxYTJ#uSHsfbbfr ... 7ZBfv2Mlj4
The upper drop-down menu is where you select the drive. The rectangle on the right part shows the flashing operations. For your drives, this should be set to WRITE Firmware.
The rectangle on the left part shows information and additional options. It will confirm whether the drive has the MT1959 platform. It should also detect automatically whether encryption is needed. Should you need it, encryption can be enabled or disabled manually as well. "Include boot loader" should be left unticked.
The lower drop-down menu will allow you to select the firmware. For the BRXL-PUS6U3B-TAA, select DE_LG_BU40N_1.03_MK.bin from the Slim External Drives folder inside Marty's All You Need Firmware Pack. (EDIT : Also, please make sure there is no disc inside the drive before you begin flashing.) When you are ready, click on START. Wait until SDFTool Flasher says "Ready" again and *do not unplug the drive during the flashing process*.
After each flash, close SDFtool Flasher, and unplug the drive and leave it unplugged for a minute. Then plug it back in, and check the MakeMKV information to make sure the flash succeeded.
For the second flash for the same drive (for DVDFab compatibility), the process is the same except encryption is not needed and the correct firmware is DE_LG_BU40N_1.00.bin from the Slim External Drives folder.
For the BRXL-16U3 (if it's an LG), same thing except you need to flash DE_LG_WH16NS60_1.02_MK.bin from the Internal Desktop Drives folder. Encryption will likely be needed. I have no idea whether this firmware is compatible with DVDFab and PlayerFab though.
EDIT : Also, regarding Cyberlink PowerDVD, it is highly unlikely you will be able to read UHD discs/ISOs with it. It should work fine with most regular Blu-ray discs/ISOs, though.
Unzip these files.
You're welcome !Thanks again for all your help. I really appreciate your willingness to prepare a guide specifically for these models. I´ll provide all the info I can about them, and probably this thread might also be useful for someone else with the same drives in the future!
foufoumalade
Flash my Pioneer
I would like to rip 4K UHD Blu-rays with my Pioneer BDR-212M drive.
Is it possible to flash the firmware of my player, given the specifications below ?
Thanking you in advance for your reply,
Best regards.
David.
Informations lecteur
Nom du lecteur SE : J:
Profil actuel : BD-ROM
Fabricant : PIONEER
Produit : BD-RW BDR-212M
Révision : 1.01
Numéro de série : ACDL009106WL
Date micrologiciel : 2020-07-21
Marqueurs d'encryptage bus : 1B
Version AACS la plus haute : 81
Drive platform: RS8F00
Firmware version: 1.01/ID56
Best regards.
David.
Fabricant : PIONEER
Révision : 1.01
foufoumalade
Flash my Pioneer BDR-212M drive
Best regards.
David.
Fabricant : PIONEER
Révision : 1.01
Best regards.
David.
Fabricant : PIONEER
Révision : 1.01
Sayaka
Hello foufoumalade,
Next time you should probably post in this subforum directly : viewforum.php?f=16
Anyway, both Coopervid and Billycar11 can help you with this one, I believe. If you do not get a reply from them soon I can notify them about this topic in case they miss your post.
Re: Flash my Pioneer BDR-212M drive
Sure email me that drive info section see below for emailfoufoumalade wrote: Wed Jul 29, 2026 10:23 am Hi,
Best regards.
David.
Fabricant : PIONEER
Révision : 1.01
Zombiciego
Sayaka wrote: Tue Jul 28, 2026 10:16 pm Here we go.
Unzip these files.
Thanks again for taking the time to prepare such a detailed guide. Amazing! I really appreciate it!
It looks like DHL has now updated the delivery estimate to Friday, so I'll have to wait a couple more days.
Once both Buffalo drives arrive, I'll first gather all the information (Drive Information, LibreDrive Information and SDFTool detection) and post everything here before flashing anything.
If everything looks as expected, I'll then follow your guide step by step. I will download the tools and firmwares while I wait for the drives.
Thanks again for all your help!
Zombiciego
Unzip these files.
Hi again Sayaka!
I'm starting with the Buffalo BRXL-16U3 desktop drive first (the big one, NOT the slim), one drive at a time as you suggested.
I wanted to double-check everything before flashing please, now that I actually have the real drives in my hands.
Here is what I found:
MakeMKV displays this info:
Información de unidad de disco
Nombre del SO del dispositivo: E:
Perfil actual: BD-ROM
Fabricante: HL-DT-ST
Producto: BD-RE BH16NS58
Revisión: 1.03
Número de serie: KLTOC591844
Fecha del firmware: 2120-05-08 09:33
Marcas de cifrado bus: 1F
Model: Buffalo BRXL-16U3-US
Internal drive: HL-DT-ST BH16NS58
Current firmware: 1.03
Blu-ray discs are detected and read perfectly.
I tested multiple UHD Blu-rays (including Alien), but none of them are detected.
The drive spins the UHD disc normally, then stops.
Windows Explorer still shows the drive as empty.
MakeMKV also reports no disc inserted / "Failed to open disc".
The same UHD discs also weren't detected by my previous LG BP50NB40, so I don't think it's a bad disc, it just requires the flashing.
The drive is powered by its original 12V/3A adapter.
USB connection is working correctly.
SDFTool flasher 1.3.6 detects my drive as E: HL-DT-ST_BD-RE__BH16NS58_1.03_212005080933_KLTOC591844
SDFTool detected (with green checkmark) that the drive has the MT1959 platform. Also that my drive has encripted firmware.
Before I continue, do you think I should simply follow your flashing guide exactly as written for this drive, or would you recommend checking or changing anything else first?
Also, is there any recommended way to back up the original Buffalo firmware before flashing? or this is not necessary/possible?
Sayaka
Hi again Zombiciego,
Thank you for this.
Also, feel free to post the BRXL-PUS6U3B-TAA information whenever you are ready.
EDIT : And I can confirm that DE_LG_WH16NS60_1.02_MK.bin likely won't work with DVDFab, so you will probably need to use the slim drive with the correct firmware when it comes to this software.
Thank you for this.
You could try but I believe there would be no point. It is extremely likely your firmware is indeed encrypted, so only a non-flashable user data area would get dumped.Also, is there any recommended way to back up the original Buffalo firmware before flashing? or this is not necessary/possible?
You can proceed. Try flashing DE_LG_WH16NS60_1.02_MK.bin with a regular WRITE with encryption, it should work on your first try. Again, no bootloader flash nor RECOVER.Before I continue, do you think I should simply follow your flashing guide exactly as written for this drive, or would you recommend checking or changing anything else first?
