Dumps Submitted - Stranger Things - Arrow UK Release
twist1ne
Re: Dumps Submitted - Stranger Things - Arrow UK Release
Post by twist1ne »
Scarbz wrote: Tue Jul 28, 2026 4:14 pm Guys what size dose the complete sessions end up being. Need to work out hdd space.
Thank you for any help
Ripping all of the episodes with only the 5.1 or 7.1 audio (no stereo tracks) and subtitles, this is what I have:
Season 1 = 225 GB
Season 2 = 251 GB
Season 3 = 249 GB
Season 4 = 415 GB
Season 5 = 328 GB
All Extras (minus image galleries) = 103 GB
1.53 TB total in file explorer
Scarbz
Post by Scarbz »
Thank you so much 👍
macdev
Post by macdev »
S5D2 and S4D3 had the same issue.
Did the backup trick and all is good.
briansemerick
Post by briansemerick »
thanks for the backup tip. S2D2 has the same problem as everyone else. backing up now.
BulldogK9
Post by BulldogK9 »
Also S5D2. Backup w/o decrypting, delete AACS folder. Load file from hard drive.
DrOct
Post by DrOct »
Glad I found this. I'm actually ripping the US release, but it seems its the same. I started with Season 5 (since I've seen the other seasons, so wanted to get this one going first), and S5D2 was driving me crazy. I would never have thought to try it without decrypting (I did try backing up, but did not occur to me to untick decrypt!). It appears to be backing up now, so fingers crossed I'll be able to get working files out of it when its done! Will keep this in mind for the other problematic discs mentioned here too!
xsoldier
Post by xsoldier »
My trouble is with S04 Disc 3 it won't rip to an MKV with the same cannot decrypt problem others have mentioned.
If I backup without decryption can I then convert it to an MKV from there?
StrangeBrew
Post by StrangeBrew »
Can anyone confirm if the foreign subtitles for Seasons 3, 4 and 5 are hardcoded or separate?
Lostsoulz
Post by Lostsoulz »
Hey
What are you Guys using to back up the trouble discs? as a ISO image? what programme?
Ive never had to do this for this century lol long time ago in the old Kazzar days I did
out of thousands of rips with MKV this will be my 1st time
DrOct
Post by DrOct »
xsoldier wrote: Fri Jul 31, 2026 6:41 pm If I backup without decryption can I then convert it to an MKV from there?
Yes, you just backup to a folder using MakeMKV (make sure to uncheck the decrypt checkbox for these ones!), delete the AACS folder in side of that folder that it will create, and then point MakeMKV at the BDMV file in that folder and it'll load up like any other disc and you can create MKVs from it like normal. Though it will probably be way faster than when you create MKVs from a disc.
DrOct
Post by DrOct »
Lostsoulz wrote: Sat Aug 01, 2026 8:59 am Hey
You just use the backup to folder feature of MakeMKV (the little folder icon in the top row)
Lostsoulz
Post by Lostsoulz »
Thanks guys :D
xsoldier
Post by xsoldier »
What is the "tell" that indicates that these discs aren't encrypted so I can check in the future?
Janssen
Post by Janssen »
DrOct wrote: Sat Aug 01, 2026 2:21 pm Yes, you just backup to a folder using MakeMKV (make sure to uncheck the decrypt checkbox for these ones!), delete the AACS folder in side of that folder that it will create, and then point MakeMKV at the BDMV file in that folder and it'll load up like any other disc and you can create MKVs from it like normal. Though it will probably be way faster than when you create MKVs from a disc.
Okay... made the back-up
Tried opening different .bmdv files (File > Open Files or File > Open DVD Manually), but then nothing happens.
I have tried:
  • /certificate/id.bdmv
  • /bdmv/MovieObj.bdmv
  • /bdmv/index.bdmv
bman7
Post by bman7 »
I'm getting a total of 1.7 TB for the whole set, full disc backups.
