huger33
Post by huger33 »
Billycar11 wrote: Sun Jul 26, 2026 12:04 am
huger33 wrote: Sat Jul 25, 2026 2:08 pm
So you recommend I try to connect my usb bp50n to the sata ports on my desktop using the guides cable recommendation and try the unlocked flasher again?
How best do i connect my optical drive to this cable? My drive has a micro usb connector, do I use a little "USB A to micro" adapter? Or use the drives stock USB A cable (which has two usb a ends, i believe for extra power delivery) and a female to female USB A connector.
You don't
See if the Asus flasher sees your drive if not
It's probably done for sorry
Dammit. It didn't. Well thanks for your time.
randomguy123
Post by randomguy123 »
Sayaka wrote: Thu Jul 16, 2026 10:57 am
Anyway, the only thing you need here is the All You Need Firmware Pack from MartyMcNuts. Do a rawflash enc,slim to DE_LG_WP50NB40-NB50_1.03_MK.bin, then a rawflash full,slim of DE_LG_WP50NB40-NB50_1.03_MK.bin, then a rawflash main,slim to DE_LG_BP60NB10_1.00_MK.bin *or* DE_LG_BU40N_1.00.bin if you want DVDFab compatibility.
With SDFTool Flasher, you would just do an encrypted flash to DE_LG_WP50NB40-NB50_1.03_MK.bin, then a RECOVER Drive, selecting DE_LG_WP50NB40-NB50_1.03_MK.bin from the pop-up window and then DE_LG_BP60NB10_1.00_MK.bin or DE_LG_BU40N_1.00.bin from the drop-down menu.
Or you can do as Billy said and e-mail him or Marty for an auto flasher.
Thanks, I had the same list, I just needed to scroll further down on the first post. Flashed!
goiopo
Post by goiopo »
MartyMcNuts wrote: Tue Jan 27, 2026 10:02 pm
AnimatedConverse wrote: Tue Jan 27, 2026 9:31 pm I can see that it's possible to use this to flash my drive, but will it work just to pick the DE_ASUS_BW-16D1HT_3.10_MK.bin or DE_ASUS_BW-16D1HT_3.02.bin firmware? My drive is the BW-16DH-U
My drive looks like this in makemkv:
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: A205
Serial number: KLQN61H0044
Firmware date: 2120-12-01 18:18
Bus encryption flags: 1F
Thanks so much!
Yes, 3.10-MK can be flashed to directly. If you want to use 3.02, you can flash to it afterwards.
thanks to MartyMcNuts ,
I recently bought an Asus BW-16D1H-T Pro and successfully flashed the firmware (3.10-MK) just now.
My device also uses the M1959 chip and the original A205 firmware.
This device wasn't on the recommended list until I saw this post .
because it's now the easiest new HUD-friendly 5.25" type to buy in my area.
(Although it's a USB 3.0 external,I'll also consider to remove the case to put in PC after the warranty expires.)
So it's helped me a lot, thank you.
KartoffeIbrei
Post by KartoffeIbrei »
Hello guys,
i just bought BU40N from Ebay, manufactured June 2019. I replaced the DVD writer in my 2016 notebook (Windows 10, https://www.notebookcheck.com/Medion-Ak ... 620.0.html) with the BU40N and installed MakeMKV. It showed me the following information:
Product: BD-RE BU40N
Revision: FR07
Serial number: 906HS017487
Firmware date: 2119-05-10 13:48
Highest AACS version: 31
I tried to flash the firmware HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin with SDFtool flasher (v 1.3.6). In the end, it says flashing was successfully, but even after notebook restart, it's still the same firmware when i have a look in MakeMKV. I am really wondering about the firmware date, because it says its from 2119. Can anyone help me? Might it be a problem with the SATA controller from my notebook?
Best wishes
KartoffeIbrei wrote: Mon Jul 27, 2026 7:24 pm Hello guys,
Revision: FR07
Best wishes
linkly no enc
but you can also email me or marty for the autoflasher
see email below
just send one of us that drive info
JSmooth
Post by JSmooth »
Subject: WH16NS40 SVC NS40 MT1939 — can this drive be flashed for UHD?
Hi all,
I have an LG WH16NS40 and want to confirm whether it can be flashed for 4K UHD ripping before I proceed.
Here are my drive specs from MakeMKV:
Product: BD-RE WH16NS40
Firmware revision: 1.02
Drive platform: MT1939
SVC code: NS40
LibreDrive Status: Enabled
BD raw metadata read: Partial
Highest AACS version: 65
LibreDrive is already enabled and regular Blu-rays rip fine. My concern is the MT1939 platform and the Partial metadata read — I've read that MT1959 is required for UHD and that NS50 SVC code is needed for safe flashing.
Can this drive be flashed to support 4K UHD, or is the MT1939 chipset a hard limitation that requires a new drive? If a new drive is needed, what would you recommend?
MrMangled
Post by MrMangled »
Hello I am new to flashing drives, I am wondering if anyone has links to blu ray drives that can easily be flashed to uhd 4k blu ray,
Thank you
JSmooth wrote: Thu Jul 30, 2026 9:08 pm Subject: WH16NS40 SVC NS40 MT1939 — can this drive be flashed for UHD?
Hi all,
SVC code: NS40
No it can't be flashed
MrMangled wrote: Thu Jul 30, 2026 10:10 pm Hello I am new to flashing drives, I am wondering if anyone has links to blu ray drives that can easily be flashed to uhd 4k blu ray,
On the 261st page of a topic that starts with a (maintained) current list of drives that can be updated to work with UHD, you ask about drives that can be updated to do UHD?
nicholfd
Post by nicholfd »
Woodstock wrote: Fri Jul 31, 2026 12:29 am
That seems to be the norm, at least on these forums. Read only the last page...
I wonder if people read books that way?
brolo
Post by brolo »
I've been trying to update this BP50NB40 NB50 that I bought on ebay to the new omnidrive. Hoping it will stop Leawo playback from freezing. It was flashed before I bought it. I've tried a bunch of things but it stays the same on mkv:
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIM21219E5826
Firmware date: 2120-05-07 09:35
Highest AACS version: 78
Firmware version: 1.02
Any idiot's guide on how to do this on a mac?
nicholfd
Post by nicholfd »
brolo wrote: Sat Aug 01, 2026 5:27 am I've been trying to update this BP50NB40 NB50 that I bought on ebay to the new omnidrive. Hoping it will stop Leawo playback from freezing. It was flashed before I bought it. I've tried a bunch of things but it stays the same on mkv:
Revision: 1.02
My understanding of Omnidrive firmware is that it does *not* change the firmware version. If your drive already had 1.02 & was patched/flashed before you received it, after flashing Omnidrive you will not see the firmware version change - Omnidrive firmware is a modified version of 1.02.
Leawo is macOS 4K/Blu-Ray/DVD player software. I am primarily a Mac user - I use a Mac to flash/test the drives I sell here on the forums. If you're seeing playback stuttering & are playing back from the source disc (not a ripped copy), it's probably your Mac/USB/system. Most people here buy flashed drives to rip media, not play it back. They rip & then watch the ripped version to avoid wearing out the expensive drive they may not be able to replace. If you rip a disc with MakeMKV, you can play it back with any software that can play MKV files. For macOS I prefer IINA
If you're asking about a guide to flash Omnidrive using a Mac, you probably won't find it here on the MakeMKV forums. Flashing discussions here are generally for using drives with MakeMKV. Your drive already has firmware to allow it work with MakeMKV.
Thanks,
Frank
Sayaka
Post by Sayaka »
Omnidrive is based on BU40N 1.00, no matter what the Omnidrive version is. If the firmware version is 1.02, I find it highly unlikely that this drive could have been flashed to Omnidrive (Omnidrive did change my firmware version when I flashed it on my BP55EB40s, for example).
I will PM this person ASAP, or if that doesn't work due to forum settings for new posters I will eventually reply here as long as the mods don't mind. While it's true that Omnidrive has nothing to do with MakeMKV, the flashing process does involve the tools we use so I feel like it's not entirely off-topic, particularly since Omnidrive has recently received improvements for DVD ripping.
EDIT : I very much agree that it is unlikely that Omnidrive has anything to do with the Leawo issues though.
Sayaka
Post by Sayaka »
Private message sent, please post in this thread again if you are unable to read it, brolo.
Also :
nicholfd wrote:My understanding of Omnidrive firmware is that it does *not* change the firmware version. If your drive already had 1.02 & was patched/flashed before you received it, after flashing Omnidrive you will not see the firmware version change - Omnidrive firmware is a modified version of 1.02.
Sayaka wrote:Omnidrive is based on BU40N 1.00, no matter what the Omnidrive version is. If the firmware version is 1.02, I find it highly unlikely that this drive could have been flashed to Omnidrive (Omnidrive did change my firmware version when I flashed it on my BP55EB40s, for example).
To clarify, if your drive already has the BU40N 1.00 firmware, flashing to Omnidrive will indeed leave the firmware version unchanged even if the flash succeeds, which may have been the source of the confusion. My apologies if this was unclear.
brolo
Post by brolo »
nicholfd wrote: Sat Aug 01, 2026 4:38 pm
Revision: 1.02
Thanks,
Frank
Thanks! All of this helps things make a lot more sense. Much appreciated.
