LibreDrive for Pioneer drives
Miromoon wrote: Sat Jul 18, 2026 3:35 am Hello,
I would like to know if my drive can be cross-flashed for UHD Blu-ray reading and which firmware is recommended.
Drive Information:
- Drive: ASUS SBW-06D5H-U
- Platform: RS8511
- Firmware name: PIONEER BDR-US03
- Firmware version: E101/ID26
- Firmware type: Original (unpatched)
- Firmware date: 2018-08-22
LibreDrive Information:
- Status: Enabled
- DVD all regions: Yes
- BD raw data read: Yes
- BD raw metadata read: Yes
- Unrestricted read speed: Yes
My UHD Blu-ray discs are currently not recognized, while regular Blu-ray discs work.
Could you please check whether this specific drive is compatible with the available UHD firmware and advise which firmware/tool should be used?
Thank you very much for your help.
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
Drive Information:
- Platform: RS8511
- Status: Enabled
PM is coming- if the forum works!
ZXG2109
Post by ZXG2109 »
Apologies if this is not the right information I am to post.
ZXG2109 wrote: Mon Jul 20, 2026 3:12 am Apologies if this is not the right information I am to post.
see below for email
agent_x007
Post by agent_x007 »
Hello
I managed to get a bit newer version of UD02D Pioneer drive (HW:1.02, SW:1.02).
Here's how sticker on top looks like (BDR-UD02DTBD) :
I attach it's capabilities to this message :
Would like to dump it's firmware before flashing, but so far no program I tried allows that :/
Any ideas ?
Eventually, I want to libredrive it, and (if possible) make it into UD03/UD04 4k capable drive (assuming a bit newer hardware revision allows that ?)
Thank you
agent_x007 wrote: Tue Jul 21, 2026 1:34 pm Hello
Any ideas ?
Thank you
might be able to be flashed to ud04 to do UHD
see below for email
agent_x007
Billycar11 wrote: Tue Jul 21, 2026 1:44 pm might be able to be flashed to ud04 to do UHD
see below for email
OS device name: H:
Manufacturer: PIONEER
Product: BD-RW BDR-UD02D
Revision: 1.02
Serial number: NCDL107266WL
Firmware date: 2014-02-10
Drive platform: Pioneer RS8410
Firmware version: ID84
movielvr15789
Post by movielvr15789 »
PIONEER BDR-212T Purchased 12-17-2022
I was able to use this drive to read/rip UHD blurays directly out of the box. No firmware update needed.
Then at some point in the last couple of years it stopped reading UHD. I have no idea why. I never made any sort of update to the drive, always used on a system running Linux Mint. The drive still works fine with regular Bluray and DVD.
I originally installed MakeMKV from source code. Later I removed and reinstalled using either the version in the Linux repository or Flatpak, not sure which. Updated to latest MakeMKV version. Not sure if the drive stopped working for UHD after changing version. Today I removed and reinstalled again from source code downloaded from MakeMKV.com. BDR-212T still doesn't read UHD.
Any idea why it worked for many months with UHD and then suddenly stopped? Can functionality be recovered with new flash or other procedure?
Thank you, drive info below.
OS device name: /dev/sr0
Current profile: DVD-ROM
Product: BD-RW BDR-212D
Revision: 1.02
Serial number: AFDL037374WL
Firmware date: 2022-03-16
Bus encryption flags: 13
Highest AACS version: 82
Drive platform: RS8F00
Firmware version: 1.02/ID61
movielvr15789 wrote: Wed Jul 29, 2026 8:58 pm PIONEER BDR-212T Purchased 12-17-2022
Revision: 1.02
Email me that makemkv drive info section see below for email
I can flash it to do UHD
Revision: 1.02
PM sent.
