My BU40N HATES StudioCanal
custarddenier
Post by custarddenier » Thu Jul 23, 2026 2:58 pm
I purchased a brand new BU40N and installed it internally in my ThinkPad L540 running Win10 LTSC 21. It has no issues for almost everything, but for some reason it has had issues exclusively with StudioCanal releases; The Trial, Mulholland Drive and various discs from the Jean-Pierre Melville collection. I have tried LibreDrive 1.00 and 1.03 patches, using an older version of MakeMKV (1.17.2) and settings tweaks. It always fails 60-70% of the way into the main movie file, sometimes producing different errors for the same disc done twice. Same Mulholland Drive disc ripped fine on a generic external drive a little over a year ago. Melvilles and The Trial were both purchased new in May, but am in process of getting them replaced to see if I just coincidentally got a bunch of bad discs. Is there anyone who has had this specific issue or similar? Any advice is appreciated.
custarddenier
Re: My BU40N HATES StudioCanal
Post by custarddenier » Thu Jul 23, 2026 3:01 pm
OS device name: F:
Product: BD-RE BU40N
Revision: 1.00
Serial number: 805HS000832
Firmware date: 2116-12-20 15:28
Highest AACS version: 76
Firmware version: 1.00
tomty89
Post by tomty89 » Fri Jul 24, 2026 12:48 pm
How are you powering the drive? If the host has a USB-C port, maybe try to connect the USB-SATA adapter to it (through a C-A adapter; or get one that has a USB-C plug).
(I've also seen USB-SATA adapters from Orico that come with a 5V USB-C power-in...)
rob4jen
Post by rob4jen » Wed Jul 29, 2026 7:39 pm
No answer for those discs specifically, but I had a stack of discs BU40N failed on. Purchased an Buffalo drive and it processed 80% of the 'bad' discs.
