I have an external HL-DT-ST BD-RE BU40N (MT1959 platform).
Several years ago I attempted to flash it using SDFtool following a guide. Unfortunately, after the flash completed, the drive never ejected again.
Current status:
- Windows detects the drive correctly.
- MakeMKV detects it correctly.
- Model: HL-DT-ST BD-RE BU40N
- Firmware reports as 1.00
- LibreDrive information is displayed normally.
- SDFtool detects the drive without problems.
- I successfully performed a READ firmware dump (2 MB).
- I successfully flashed DE_LG_BU40N_1.03_MK.bin using SDFtool v1.3.5.
- Flash finished with "Done Successfully".
However:
- The tray still does not eject using either the hardware eject button or MakeMKV.
- Windows Explorer never shows a disc drive.
- The tray can only be opened with the emergency pin hole.
- No disc is inside.
- The drive is inside an ODP95-SU3 USB enclosure.
Could this indicate corrupted NVRAM / calibration data rather than the main firmware?
Would RECOVER mode be the recommended next step, or is there another recovery procedure for this condition?
I can provide:
- Full firmware dump
- SDFtool screenshots
- MakeMKV screenshots
Thank you.
BU40N - Drive detected, firmware readable, flashing succeeds, but eject no longer works
Re: BU40N - Drive detected, firmware readable, flashing succeeds, but eject no longer works
i would assume it the case
post the makemkv drive info section in plain text
and try it out of the case with one of the adapters from the guide
Thank you.
I will post the complete MakeMKV drive information in plain text.
Regarding the enclosure, it is currently installed in an ODP95-SU3 USB enclosure. I will try the drive with one of the recommended adapters from the UHD guide and report back.
OS device name: F:
Product: BD-RE BU40N
Revision: 1.00
Serial number: MDEFASI0453
Firmware date: 2116-12-20 15:28
Highest AACS version: 66
Firmware version: 1.00
Since the issue started immediately after a firmware flash years ago, do you still think this is more likely to be the USB enclosure rather than corrupted firmware/NVRAM?
OS device name: F:
Revision: 1.00
i was expecting it to be in boot mode seen that with cheap adaptersisaactr13 wrote: Tue Jul 28, 2026 5:28 am Thank you.
OS device name: F:
Revision: 1.00
email me your dump file see below for email how did you do a full backup with dosflash?
if so also dump your current fw and i will look at them
ok emailed you just to update everyone elseBillycar11 wrote: Tue Jul 28, 2026 6:58 ami was expecting it to be in boot mode seen that with cheap adaptersisaactr13 wrote: Tue Jul 28, 2026 5:28 am Thank you.
OS device name: F:
Revision: 1.00
drive has cal data and sn
still unsure how you got full dumps over usb
but im leaning towards this case is messing up drives some how saw another post from a few years ago and theirs was also acting like it was dead after flashing
viewtopic.php?t=29558
try a new case and reflashing with unlocked lg flasher to bu40n 1.00
