huger33
Post by huger33 » Sun Jul 26, 2026 12:36 am
Billycar11 wrote: Sun Jul 26, 2026 12:04 am
huger33 wrote: Sat Jul 25, 2026 2:08 pm
So you recommend I try to connect my usb bp50n to the sata ports on my desktop using the guides cable recommendation and try the unlocked flasher again?
How best do i connect my optical drive to this cable? My drive has a micro usb connector, do I use a little "USB A to micro" adapter? Or use the drives stock USB A cable (which has two usb a ends, i believe for extra power delivery) and a female to female USB A connector.
You don't
See if the Asus flasher sees your drive if not
It's probably done for sorry
Dammit. It didn't. Well thanks for your time.
randomguy123
Post by randomguy123 » Sun Jul 26, 2026 3:04 am
Sayaka wrote: Thu Jul 16, 2026 10:57 am
Anyway, the only thing you need here is the All You Need Firmware Pack from MartyMcNuts. Do a rawflash enc,slim to DE_LG_WP50NB40-NB50_1.03_MK.bin, then a rawflash full,slim of DE_LG_WP50NB40-NB50_1.03_MK.bin, then a rawflash main,slim to DE_LG_BP60NB10_1.00_MK.bin *or* DE_LG_BU40N_1.00.bin if you want DVDFab compatibility.
With SDFTool Flasher, you would just do an encrypted flash to DE_LG_WP50NB40-NB50_1.03_MK.bin, then a RECOVER Drive, selecting DE_LG_WP50NB40-NB50_1.03_MK.bin from the pop-up window and then DE_LG_BP60NB10_1.00_MK.bin or DE_LG_BU40N_1.00.bin from the drop-down menu.
Or you can do as Billy said and e-mail him or Marty for an auto flasher.
Thanks, I had the same list, I just needed to scroll further down on the first post. Flashed!
goiopo
Post by goiopo » Mon Jul 27, 2026 10:04 am
MartyMcNuts wrote: Tue Jan 27, 2026 10:02 pm
AnimatedConverse wrote: Tue Jan 27, 2026 9:31 pm I can see that it's possible to use this to flash my drive, but will it work just to pick the DE_ASUS_BW-16D1HT_3.10_MK.bin or DE_ASUS_BW-16D1HT_3.02.bin firmware? My drive is the BW-16DH-U
My drive looks like this in makemkv:
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: A205
Serial number: KLQN61H0044
Firmware date: 2120-12-01 18:18
Bus encryption flags: 1F
Thanks so much!
Yes, 3.10-MK can be flashed to directly. If you want to use 3.02, you can flash to it afterwards.
thanks to MartyMcNuts ,
I recently bought an Asus BW-16D1H-T Pro and successfully flashed the firmware (3.10-MK) just now.
My device also uses the M1959 chip and the original A205 firmware.
This device wasn't on the recommended list until I saw this post .
because it's now the easiest new HUD-friendly 5.25" type to buy in my area.
(Although it's a USB 3.0 external,I'll also consider to remove the case to put in PC after the warranty expires.)
So it's helped me a lot, thank you.
