Newbie can get things to work; plz help
sunny
#1 Post by sunny » Sun Dec 06, 2009 11:08 pm
Hey all,
I can't seem to get makemkv to successfully read my blu-rays. I am using beta version 1.4.9.
Hardware:
Core2Duo 2.16ghz imac 10.6.1 4GB RAM
LG model HL-DT-ST BD-RE WH08LS20
-sata Blu-ray burner 8x DVD burner 16x
OWC Sata to USB2 external drive case
internal Matshita DVD-R superdrive
I have used safari to download the "allcombo.svq" file to a directory labeled MakeMKV on user/sunny/documents/MakeMKVds using the save file to command.
I can't seem to get to dump into a .txt file despite checking the text box in the preference menu.
Attached is a screen capture of the program window. Any help would be appreciated
Sunny
Re: Newbie can get things to work; plz help
#2 Post by mike admin » Mon Dec 07, 2009 8:31 am
you need to save SVQ file as binary file, in firefox you can use "save link as" menu, safari should have similar command.
VBLUE42
#3 Post by VBLUE42 » Sat Jan 02, 2010 11:14 pm
I am having this same issue with a BD-ROM drive. I have the SQV. Can anyone make any suggestions?
