BDR-XS07S UHD Flash
Re: BDR-XS07S UHD Flash
#346 Post by Coopervid » Thu Jul 16, 2026 3:56 pm
diablobobo wrote: Thu Jul 16, 2026 3:19 am Hi Coopervid,
I also got a Pioneer BDR-XS07 with Firmware 1.01.
Can you please send me a PM with the Informations to upgrade?
Thank you so much :-)
PM sent.
#347 Post by Billycar11 » Thu Jul 16, 2026 10:26 pm
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
Excalibur-CH
#348 Post by Excalibur-CH » Thu Jul 23, 2026 6:11 am
I have also a
Firmware version: 1.01/ID05
with a FW version date 03. Sept. 2020. So far, I haven't had an issue with ripping 4K movies onto my hard drive. But Mortal Kombat II (2026 version) is refusing to get ripped. MakeMKV complains, it is missing decryption key, passkey doesn't work with my Pioneer BD drive at all.
Do I really have to put in different FW or is it only this specific movie? If the recommendation is, to use different FW, can someone please DM me the instructions for it?
Thank you in advance.
Ps. I am ripping the movies to watch the 4k versions on my computer and this is the only way to do it.
#349 Post by dcoke22 » Thu Jul 23, 2026 12:25 pm
Excalibur-CH wrote: Thu Jul 23, 2026 6:11 am I have also a
If MakeMKV says it is missing a decryption key, then it undoubtedly produced a dump file. Attach that .tgz file to an email and send to svq@makemkv.com. Eventually a hashed key will be made that MakeMKV can download and decrypt the disc in question. There are more details in the UHD FAQ.
Additionally, MakeMKV can use the Public KeyDB. The necessary decryption key might already be there, but if not the dump file can be submitted there are well.
If your drive works for other 4K discs you should not need to change the firmware on your drive.
Excalibur-CH
#350 Post by Excalibur-CH » Thu Jul 23, 2026 2:15 pm
I have sent the dump file about 7 days ago already and it will be automatically uploaded, each time MakeMKV fails to read the disk.. As such, I am currentl "spamming" them with dump files :lol:
But the public key works.. ripping as I write this.
caden
#351 Post by caden » Sun Jul 26, 2026 12:49 pm
I also have the BDR-XS07S with fw 1.01 I'd like to update it's firmware. Thanks alot.
Manufacturer: PIONEER
Product: BD-RW BDR-XS07
Revision: 1.01
Serial number: [Redacted]
Firmware date: 2020-09-03
Bus encryption flags: 13
Highest AACS version: 63
Drive platform: RS8E20
Julzfreezz
#352 Post by Julzfreezz » Sun Jul 26, 2026 4:48 pm
Well I also got a BDR-XS07TS laying around.
Laufwerksinformation
OS-Gerätename: H:
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-XS07
Revision: 1.01
Serienummer: BFDL006504WL
Firmware-Datum: 2020-09-03
Markierungen der Bus-Verschlüsselung: 13
Highest AACS version: 81
Unfortunately I can´t PM you guys directly.
Could you give me the Information how to Crossflash the Firmware and which Firmware I have to use?
@Billycar11 and @Coopervid
Would be awesome!
#353 Post by Coopervid » Sun Jul 26, 2026 5:30 pm
caden wrote: Sun Jul 26, 2026 12:49 pm I also have the BDR-XS07S with fw 1.01 I'd like to update it's firmware. Thanks alot.
Revision: 1.01
PM sent.
#354 Post by Coopervid » Sun Jul 26, 2026 5:32 pm
Julzfreezz wrote: Sun Jul 26, 2026 4:48 pm Well I also got a BDR-XS07TS laying around.
OS-Gerätename: H:
Produzent: PIONEER
Revision: 1.01
Would be awesome!
PM sent.
Streamline
#355 Post by Streamline » Sun Jul 26, 2026 6:41 pm
Hi Coopervid,
I recently purchased a Pioneer BD-RW BDR-XS07 and would like to flash it with LibreDrive firmware to enable UHD Blu-ray reading capabilities. I understand from this thread that you've been helping others with the process, so I was wondering if you could kindly share the firmware files and instructions.
Below is my current MakeMKV drive information:
OS device name: G:
Revision: 1.01
Serial number: -
Could you please send me the firmware file and flashing instructions via private message? I'll follow the guidelines carefully and take appropriate precautions during the process.
I appreciate your time and the community effort you're providing. Thank you very much!
Best regards,
Streamline
#356 Post by Billycar11 » Sun Jul 26, 2026 11:49 pm
Streamline wrote: Sun Jul 26, 2026 6:41 pm Hi
OS-Gerätename: H:
Produzent: PIONEER
Revision: 1.01
Would be awesome!
OS device name: G:
Revision: 1.01
Serial number: -
Best regards,
Streamline
Revision: 1.01
all others email me no need to post your info here publicly just reach out to me directly
see below for email
Julzfreezz
#357 Post by Julzfreezz » Mon Jul 27, 2026 7:07 am
Coopervid wrote: Sun Jul 26, 2026 5:32 pm
OS-Gerätename: H:
Produzent: PIONEER
Revision: 1.01
Would be awesome!
PM sent.
Haven´t figured out how to reply on the pm but it worked perfectly!! Thanks alot!
EM2230
BDR-XS07SU UHD Flash
#358 Post by EM2230 » Sat Aug 01, 2026 4:41 pm
I would also like to get my drive done please
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number: CKDL016060UC
Firmware date: 2023-01-06
Highest AACS version: 77
Drive platform: RS8E21
Firmware version: 1.03/ID05
#359 Post by Coopervid » Sun Aug 02, 2026 9:50 am
Streamline wrote: Sun Jul 26, 2026 6:41 pm Hi Coopervid,
OS device name: G:
Revision: 1.01
Serial number: -
Best regards,
Streamline
PM sent.
Re: BDR-XS07SU UHD Flash
#360 Post by Billycar11 » Sun Aug 02, 2026 10:03 am
EM2230 wrote: Sat Aug 01, 2026 4:41 pm I would also like to get my drive done please
Revision: 1.03
your drive does not need to be flashed
if you need support email below
