PIONEER BDR-209 change the Firmware ?
Re: PIONEER BDR-209 change the Firmware ?
Post by Billycar11 » Sun Jun 28, 2026 12:40 pm
vitolwein wrote: Sun Jun 28, 2026 1:44 am Hello! can you help me please?
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-209D
Revision: 1.51
Serial number:
Firmware date: 2018-05-08
Bus encryption flags: 13
Drive platform: RS8600
Firmware version: 1.51
sure email me that info see below
Post by Coopervid » Sun Jun 28, 2026 6:33 pm
OS device name: G:
Revision: 1.51
Serial number:
PM sent.
aduma
Post by aduma » Sun Jul 26, 2026 4:15 am
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
Serial number: <redacted>
Firmware date: 2018-01-15
Highest AACS version: 81
Firmware version: E102/ID76
Seeking the ability to read UHD disks. Thank you.
Post by Coopervid » Sun Jul 26, 2026 5:34 pm
aduma wrote: Sun Jul 26, 2026 4:15 am Drive Information
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
PM sent.
Post by Billycar11 » Sun Jul 26, 2026 11:45 pm
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
sure email me that info and
all others email me no need to post your info here publicly just reach out to me directly
see below for email
spily74
Post by spily74 » Fri Aug 07, 2026 2:08 pm
Salve, potrei avere un aiuto sulla mia unità per renderla compatibile uhd/4k?
Grazie
Informazioni unità
Nome dispositivo SO: F:
Produttore: PIONEER
Prodotto: BD-RW BDR-209M
Revisione: 8.50
Numero seriale: RHDL026808WL
Data firmware: 2017-12-21
Flag criptazione bus: 1B
Versione più recente AACS: 52
Informazione LibreDrive
Stato: Abilitato
Piattaforma unità: RS8601
Nome firmware: PIONEER BDR-209
Tipo firmware: Originale (non modificato)
Versione firmware: 8.50/ID52
DVD tutte le regioni: Sì
Lettura dati BD raw: Sì
Lettura metadati BD raw: Sì
Velocità di lettura senza restrizioni: Sì
Nessun disco inserito
Post by Coopervid » Fri Aug 07, 2026 5:25 pm
spily74 wrote: Fri Aug 07, 2026 2:08 pm Salve, potrei avere un aiuto sulla mia unità per renderla compatibile uhd/4k?
Grazie
Informazioni unità
Produttore: PIONEER
Revisione: 8.50
Stato: Abilitato
PM sent.
Post by Billycar11 » Fri Aug 07, 2026 8:36 pm
Grazie
Informazioni unità
Produttore: PIONEER
Revisione: 8.50
Stato: Abilitato
see below for email
spily74
Post by spily74 » Sat Aug 08, 2026 9:49 am
Coopervid wrote: Fri Aug 07, 2026 5:25 pm
Grazie
Informazioni unità
Produttore: PIONEER
Revisione: 8.50
Stato: Abilitato
PM sent.
mi da messaggio errore con UHD/4K Super MArio Bros the movie:
https://ibb.co/LdF6GqWm
Post by Coopervid » Sat Aug 08, 2026 5:19 pm
spily74 wrote: Sat Aug 08, 2026 9:49 am
Grazie
Informazioni unità
Produttore: PIONEER
Revisione: 8.50
Stato: Abilitato
PM sent.
Wash the disc with liquid soap and warm water. Dry with a paper towel and wipe then with a microfiber cloth.
domogled
Post by domogled » Sun Aug 09, 2026 9:35 pm
just wondering if my old Pioneer BDR209D can be upgraded to a UHD drive able both for reading and writing UHD drives and if the answer is positive might it be able to write on 100GB discs?
Here are the details of this drive I have:
OS device name: K:
Revision: 1.20
Serial number: NKDL053075WK
Firmware date: 2014-04-08
Firmware version: 1.20/ID61
Thank you for your precious time and support
Post by Billycar11 » Mon Aug 10, 2026 1:07 am
domogled wrote: Sun Aug 09, 2026 9:35 pm Hello,
OS device name: K:
Revision: 1.20
see below for email
Post by Coopervid » Mon Aug 10, 2026 9:07 am
OS device name: K:
Revision: 1.20
PM sent.
domogled
Post by domogled » Fri Aug 14, 2026 1:42 pm
hi guys,
thank you very much both for replying to my enquiry, sorry for late reply, busy week :) I confirm I received your PM Coopervid, tried to reply but I got limited functionality on my new account here. I will try the tutorial this weekend and come back to you with the result. Happy you confirm this drive is compatible with the upgrade solution, I really thought it might be too old for such an attempt.
I have an older drive, barely used which I wonder if it might be converted too, I will raise the question in the appropriate section of the forum.
thanks again
matsd
Post by matsd » Fri Aug 14, 2026 4:43 pm
can my Pioneer BDR209 be upgraded to a UHD drive
Revision: 1.51
Serial number: NHDL040381WL
Firmware version: 1.51/ID61
