Pioneer BDR-S12U - UHD Issues: Is a Firmware Update Worth It?
bimbi
#1 Post by bimbi » Sat Jul 25, 2026 6:35 pm
Hello all,
A few years ago, I bought a UHD drive here on the forum: the “PIONEER BDR-S12U.” It “mostly” worked pretty well. But over the last two years, it's gotten worse and worse. Lots of read errors, I/O errors, SCSI errors...
What helped was restarting the PC, cleaning the disc (even though there was no visible dirt), reinserting the disc, and trying again, and again, and again. Eventually, I’d get lucky and the copy would work. Sometimes I’d just exchange the disc on Amazon, and the replacement would work right away. It was all pretty strange.
Anyway, here’s the situation. Seven days ago, “Avatar 3”-> no problem. And now I’m trying to add the "Transformers 7 Movie Collection" to my media collection; so far, I’ve only managed to move two discs. And I’ve been at it for almost a week.
System: Kubuntu 26.04 LTS
Here are my drive’s specs:
OS device name: /dev/sr1
Manufacturer: PIONEER
Product: BD-RW BDR-S12U
Revision: 1.01
Serial number: BCDL006587WL
Firmware date: 2020-07-21
Highest AACS version: 82
Drive platform: RS8F01
Firmware version: 1.01/ID43
Disc Information
Label: REVENGE OF THE FALLEN
Timestamp: 2017-10-09 17:46:36
Protection: AACS2.0/C v61
Data capacity: 89.15 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Do you think updating the firmware would help?
I know it doesn't help right now, but it's incredibly annoying. You buy some UHD Movie you can't really use. What a shame that the movie market has become so complicated.
Best Regards :)
Re: Pioneer BDR-S12U - UHD Issues: Is a Firmware Update Worth It?
#2 Post by MartyMcNuts » Sat Jul 25, 2026 11:35 pm
bimbi wrote: Sat Jul 25, 2026 6:35 pm Hello all,
Revision: 1.01
Disc Information
Number of layers: 3
Best Regards :)
No, firmware has absolutely nothing to do with problems reading discs. Try cleaning the lasers.
bimbi
#3 Post by bimbi » Sun Jul 26, 2026 9:27 am
Thank you for your reply. So buy a cleaning set like this could help?
Cleaningset1
Cleaningset2
#4 Post by Billycar11 » Sun Jul 26, 2026 9:30 am
bimbi wrote: Sun Jul 26, 2026 9:27 am
Cleaningset1
Cleaningset2
:lol:
no take it apart and clean it with lint free cloths and water or alcohol
eject tray
unplug drive with tray out
pop off front bezel clips on sides and bottom with plastic tool
undo screws from bottom will be under stickers if you have an s13, 213 does not have stickers.
flip backover and remove top cover
clean lasers with a lint free cloth or qtip and water or alcohol and dry with another do this 2 times and do not let it air dry you must remove the residue with a dry one!
bimbi
#5 Post by bimbi » Sun Jul 26, 2026 9:37 am
Oh, okay, thanks a lot. I didn't know I could do it that way. I will do that over the next week :-)
