#1786
Post
by MartyMcNuts » Tue Jul 21, 2026 4:48 am
jeremykunut wrote: Tue Jul 21, 2026 3:01 am
Hi Marty,
I just got an Archgon drive and found that it doesn't work right away with MakeMKV, which has led me here. I'm new to the concept of flashing, but your GUI seems pretty user-friendly. I am a little confused about the different .zip files--I'm assuming I only need the newest version of the GUI (v1.3.6), but I have questions about the All You Need Firmware Pack:
I've seen several warnings about not flashing desktop firmware to slim drives, which I think applies to me with my Archgon drive? And for those who are new to this like I am, that means to AVOID the "Internal Desktop Drives" folder in All You Need? Looking into the Slim External Drives folder, I only see files that say LG and Buffalo. Is there a specific file I need to open once I have selected my drive? Or do I need an Archgon file that is not here in the folder?
Also, I saw something about dumping firmware from the drive. Is that a step that I need to do in order to remove the existing firmware so that I can do the necessary downgrade? And I guess that the folder that will be created is just there to save the files in case I ever need to put them back onto the drive?
The Archgon contains a LG BU40N drive inside it's enclosure.
No, the firmware cannot be dumped, only the important cal data.
Don't be surprised if it won't flash as Archgon changed something in their enclosures that stop flashing commands and libredrive from being passed through to the drive. You would likely have to permanently remove the drive from the enclosure to flash and use. Probably better to return it if you can and get something else.
#1787
Post
by Billycar11 » Tue Jul 21, 2026 7:29 am
Hi Marty,
archgon is likely a LG BU40N
but most archgons dont support flashing in the case
Xeth84
#1788
Post
by Xeth84 » Sat Jul 25, 2026 3:44 pm
I just bought an Asus BW-16D1HT and tried to flash it with the SDFtool
I get an error
The guide says "Asus BW-16D1HT on any Firmware directly to > Asus BW-16D1HT 3.10MK"
What am I doing wrong?
Xeth84 on Sat Jul 25, 2026 3:49 pm, edited 1 time in total.
#1789
Post
by Billycar11 » Sat Jul 25, 2026 3:47 pm
Xeth84 wrote: Sat Jul 25, 2026 3:44 pm
I get an error
Your drive is 12+ years old
Likely a fake recase that's says it was built in the 2020s
See a lot of these everyday
Xeth84
#1790
Post
by Xeth84 » Sat Jul 25, 2026 3:56 pm
Billycar11 wrote: Sat Jul 25, 2026 3:47 pm
I get an error
So where do I find a drive that is not fraudulent?
#1791
Post
by Billycar11 » Sat Jul 25, 2026 4:01 pm
Xeth84 wrote: Sat Jul 25, 2026 3:56 pm
I get an error
You go to b&h
Xeth84
#1792
Post
by Xeth84 » Sat Jul 25, 2026 4:10 pm
Billycar11 wrote: Sat Jul 25, 2026 4:01 pm
You go to b&h
Is there a drive that I should look for? They no longer have the Asus BW-16D1HT.
#1793
Post
by Billycar11 » Sat Jul 25, 2026 4:21 pm
Xeth84 wrote: Sat Jul 25, 2026 4:10 pm
You go to b&h
one of the 2 Buffalos
Xeth84
#1794
Post
by Xeth84 » Sat Jul 25, 2026 6:34 pm
Billycar11 wrote: Sat Jul 25, 2026 4:21 pm
You go to b&h
Thank you. I will try it.
ToadTheMagic Dragon
#1795
Post
by ToadTheMagic Dragon » Thu Jul 30, 2026 11:30 pm
Just bought a Buffalo Mediastation 6X Portable BDXL Blu-Ray Writer with M-Disc Support (TAA Compliant) model BRXL-PUS6U3B-TU.
Flashed w/DE_Buffalo_BRUHD-PU3_BN12-MK.bin for full LibreDrive support. Limited use but so far, so good ...
"Once Upon a Time ... there was a Magic Dragon named Toad"
in a land far far away
ToadTheMagic Dragon
#1796
Post
by ToadTheMagic Dragon » Fri Jul 31, 2026 2:50 am
I discovered the BN12file will not read UHD discs. Use DE_Buffalo_BRUHD-PU3_BU12-MK.bin to enable UHD disc decoding ...
#1797
Post
by Billycar11 » Fri Jul 31, 2026 2:52 am
ToadTheMagic Dragon wrote: Fri Jul 31, 2026 2:50 am
no one told you to flash bn12
we recommend BU40N 1.03
ToadTheMagic Dragon
#1798
Post
by ToadTheMagic Dragon » Fri Jul 31, 2026 2:57 am
Ok I will give that one a try. A bit challenging for my little brain trying to decipher all the posts pertaining to drives and firmware. I was just trying to share my experience with the drive I bought (from B&H).
All the time and effort by you folks is definitely appreciated!
Thank you
ionas
#1799
Post
by ionas » Tue Aug 04, 2026 10:43 am
Hi! I bought a LG 5.25 Drive (BH16NS55 1.02) and want to flash it using my linux server (where ARM is installed). Since my Makemkv is the latest i need to flash it with the sdf tool. I downloaded it from mediafire and recognized it's an exe. Is there a way to flash it directly from linux?
My version: MakeMKV v1.18.4 linux(x64-release)
Thank you!
#1800
Post
by Billycar11 » Tue Aug 04, 2026 11:17 am
ionas wrote: Tue Aug 04, 2026 10:43 am
Thank you!
Just use cli on Linux why complicate things
