Kill Bill: The Whole Bloody Affair UHD rip not progressing
OddOttAllen
Post by OddOttAllen »
hi there! sorry if this is a common issue that has a fix that's widely known, i'm not really here a lot and Google hasn't helped me.
i'm currently attempting to rip the new UHD release of Kill Bill: The Whole Bloody Affair and i'm having this weird issue where the MKV-making stops at 654.1 MB and doesn't progress. the time remaining just continues to increase, going past 10 hours remaining with no progress made after 10 minutes. is this another sneaky Lionsgate rip protection thing going on, or my drive being weird, or... something else?
if it helps, i got the ASUS BW-16D1HT, connected externally.
bjchurton
Re: Kill Bill: The Whole Bloody Affair UHD rip not progressing
Post by bjchurton »
Good, its not just me! Weird thing is it is both discs stalling at 654MB
OddOttAllen
bjchurton wrote: Sat Jul 25, 2026 12:56 am Good, its not just me! Weird thing is it is both discs stalling at 654MB
wait, i'm not the only one?? oh my god, i thought it was my drive or my discs or something! i wonder what's causing this...
are you using the asus or ud04
bjchurton
Post by bjchurton »
UD04
reduser28
Post by reduser28 »
Having the same problem. Stauls at 636M for me.
OddOttAllen
i really do wonder what it could be then. i've been able to rip everything else from the UHDs besides the movie, and the bonus fortnite special on the first disc. that's including the menu videos and logos and piracy screens and whatnot.
the 1080p BDs are just fine btw, it's only the UHDs in this instance
Post by SamuriHL »
Mine was supposed to be delivered today but has been delayed. Hopefully Monday. I'll see if I have the same issue. May be a mastering issue potentially or just a bad batch of discs.
OddOttAllen
i don't really feel like returning anything... has anyone tried this with the standard edition discs? or is it all happening with the collector's edition?
JuddSandage
Post by JuddSandage »
Also having the same issue, though I cant read the second disc as it comes up with an unknown volume key.
Drives: WH16NS40x2, BW-16D1HT, BE16NU50.
bjchurton
Post by bjchurton »
OddOttAllen wrote: Sat Jul 25, 2026 8:45 pm i don't really feel like returning anything... has anyone tried this with the standard edition discs? or is it all happening with the collector's edition?
Mine was the Standard Edition
Chincino
Post by Chincino »
I made an account just to talk about this, I have the collectors edition. Disc one successfully ripped, though it took a really long time, I had walked away and was surprised to see 4 hours later it hadn't completed. Disc two stalled out at 938mb for me. This is for the UHD, I have a S13 UBK
cachookaman
Post by cachookaman »
I have the same drive and have the same issue
MakeMKV v1.18.4 win(x64-release) started
Using LibreDrive mode (v06.3 id=E064BA3E3F81)
Title #00012.mpls has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00101.mpls has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00100.mpls was added as title #0
File 00001.mpls was added as title #1
Title #00017.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00005.m2ts was added as title #2
Title #00004.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00000.m2ts was added as title #3
Title #00002.m2ts has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory D:/Movies/Kill Bill- The Whole Bloody Affair Disc 1
AV synchronization issues were found in file 'D:/Movies/Kill Bill- The Whole Bloody Affair Disc 1/Kill Bill- The Whole Bloody Affair Disc 1_t01.mkv' (title #2)
AV sync issue in stream 0 at 0:01:31.800 : video frame timecode differs by -0.1ms
AV sync issue in stream 0 at 0:01:31.800 : secondary stream video frame timecode differs by +83.322ms
AV sync issue in stream 0 at 0:01:31.966 : video frame timecode differs by -0.1ms
AV sync issue in stream 0 at 0:01:31.966 : secondary stream video frame timecode differs by -0.1ms
AV sync issue in stream 0 at 0:01:31.966 : secondary stream video frame timecode differs by +125.033ms
AV sync issue in stream 0 at 0:01:32.133 : video frame timecode differs by -0.1ms
AV sync issue in stream 0 at 0:01:32.133 : secondary stream video frame timecode differs by -0.1ms
AV sync issue in stream 0 at 0:01:32.133 : secondary stream video frame timecode differs by +83.321ms
AV sync issue in stream 0 at 0:01:32.300 : video frame timecode differs by -0.1ms
AV sync issue in stream 0 at 0:01:32.300 : secondary stream video frame timecode differs by -0.1ms
AV sync issue in stream 0 at 0:01:32.300 : secondary stream video frame timecode differs by +83.321ms
AV sync issue in stream 0 at 0:01:32.467 : video frame timecode differs by -0.1ms
AV sync issue in stream 0 at 0:01:32.467 : secondary stream video frame timecode differs by -0.1ms
AV sync issue in stream 0 at 0:01:32.467 : secondary stream video frame timecode differs by +83.321ms
rhett7660
Post by rhett7660 »
I am having the same issue. 654.1 MB and then it stops.
OS device name: /dev/rdisk16
Product: BD-RE BU40N
Revision: 1.00
Serial number: MOEL91D5651
Firmware date: 2116-12-20 15:28
Highest AACS version: 82
Firmware version: 1.00
OddOttAllen
Xreveal was able to decrypt the video, so i was able to make an MKV from that with both discs. this could just be a program issue.
