i finally got a UD04 based of the 4k recommendation guide, but mine shows that the libredrive is not enabled and it cannot read 4k right not.
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.00
Firmware date: 2016-11-14
Highest AACS version: 82
Drive platform: Pioneer RS8A10
Firmware version: ID19
How to enable libredrive on Pioneer UD04
Re: How to enable libredrive on Pioneer UD04
PM sent.Nova22 wrote: Mon Jun 22, 2026 7:39 pm i finally got a UD04 based of the 4k recommendation guide, but mine shows that the libredrive is not enabled and it cannot read 4k right not.
Revision: 1.00
Thank you!Coopervid wrote: Tue Jun 23, 2026 10:18 amPM sent.Nova22 wrote: Mon Jun 22, 2026 7:39 pm i finally got a UD04 based of the 4k recommendation guide, but mine shows that the libredrive is not enabled and it cannot read 4k right not.
Revision: 1.00
do you know if I will need to update a BDR-XD05S? have one coming soon!
Yes. We will make it UHD capable.
there were some bugs, but its correctNova22 wrote: Mon Jun 22, 2026 7:39 pm i finally got a UD04 based of the 4k recommendation guide, but mine shows that the libredrive is not enabled and it cannot read 4k right not.
Revision: 1.00
OS device name: F:
Product: BD-RW BDR-XD06U
Revision: 1.11
Serial number: NIDL001216JP
Firmware date: 2017-06-22
Drive platform: RS8B30
Firmware name: PIONEER BDR-XS06
Firmware version: 1.11/ID69
extrachange
Hi, I got the same drive that shows the same info in makemkv, is this FW version not supported? Can I get some help?Coopervid wrote: Tue Jun 23, 2026 10:18 amPM sent.Nova22 wrote: Mon Jun 22, 2026 7:39 pm i finally got a UD04 based of the 4k recommendation guide, but mine shows that the libredrive is not enabled and it cannot read 4k right not.
Revision: 1.00
sure email me that info and all others email me no need to post your info here just reach out to me directlyextrachange wrote: Thu Jul 23, 2026 2:28 pm
see below for email
PM sent.extrachange wrote: Thu Jul 23, 2026 2:28 pmHi, I got the same drive that shows the same info in makemkv, is this FW version not supported? Can I get some help?Coopervid wrote: Tue Jun 23, 2026 10:18 amPM sent.Nova22 wrote: Mon Jun 22, 2026 7:39 pm i finally got a UD04 based of the 4k recommendation guide, but mine shows that the libredrive is not enabled and it cannot read 4k right not.
Revision: 1.00
