What firmware for Verbatim 438888?
MintyHippp69
Post by MintyHippp69 »
Hello
I've recently got a Verbatim 438888, and I beleive that the drive inside is an LG one, not an older Pioneer one.
I'm looking to, I think, flash this so I can then use it to backup some Blu-Rays I have, I currently don't have any 4k/UHD Blu-Rays yet, but I have got my eyes on a few, so to future proof I believe that I'd need the correct firmware to do this. They're also mainly Region B, but I have a few Region A, which I can use on my stand-alone region free player for my TV, but I'not m sure how that effects things for this Verbatim drive, or how that would effect the player for general playback use. I believe that this is software based not hardware like DVD, so does flashing prevent things like this or it a case of staying away from certain players?
Having looked a round, I believe you may need this information to help.
OS device name: F:
Product: BD-RE BU40N
Revision: 1.05
Serial number: ------------
Any help would be appreciated.
Thank you.
Re: What firmware for Verbatim 438888?
See guide below or
Email me or Marty for the auto flasher
See below for my email
Sayaka
Post by Sayaka »
MintyHippp69 wrote: Mon Jul 20, 2026 2:31 pm I've recently got a Verbatim 438888
I believe you mean "Verbatim 43888". There is no such thing as a "Verbatim 438888". Nitpicking, I know. :)
From a quote by "bobbster574" on Reddit, which I believe explains things pretty well :
Blu-ray region locking is entirely software based. While a dedicated player has a preset region, a Blu-ray drive for a pc does not, and it's down to the player software you use to enforce region locking.
Official software for Blu-ray playback (e.g. powerDVD) will enforce region locking, but may give you a set number of chances (often 5) to change the region. This is linked to the software, not the drive. Depending on the software, it may be possible to reset the region changes available, but it's not something I've looked into a whole lot.
Unofficial software, on the other hand, may not enforce region locking at all, or will enforce it while offering you unlimited region swaps.
To this I will add that if you make a full, decrypted "folder backup" of a region-locked Blu-ray disc with MakeMKV and then turn that backup into an ISO file, the "software-enforced" region locking may still apply. For example, you would still need to set the region in Kodi.
UHD discs are *supposed* to be region-free, although according to some people you may run into exceptions.
OS device name: F:
Revision: 1.05
Thank you.
That's an LG BU40N indeed. You are using Windows, so please have a look here : viewtopic.php?t=22896
Download the latest version of SDFTool Flasher as well as the All You Need Firmware Pack (unzip both, don't just double-click on the zip files otherwise Windows may attempt to open them without unzipping them), and have a look inside the "Slim External Drives" folder inside the All You Need Firmware Pack. The firmware you want is DE_LG_BU40N_1.03_MK.bin
Flash that firmware with SDFTool Flasher with a regular WRITE with encryption (encryption should be ticked by default for the 1.05 firmware you drive has right now). No READ (well, you could but it would be pointless), no bootloader flash, and no RECOVER. After flashing, wait until SDFTool Flasher says "Ready" again before closing it. Then unplug the drive (please do not unplug it during the flashing process, only after the flashing is fully finished !), leave it unplugged for 30 seconds just in case, and plug it back in. Check your LibreDrive Information again.
Then repeat the process (without encryption in SDFTool Flasher this time around) with DE_LG_BU40N_1.00.bin if you want DVDFab compatibility (optional).
MintyHippp69
Thank you Billycar11, I read through the guide, it got a little confusing as I've been out of the game of doing things like this for a while, but I did find someone with a YT Tutorial using the same drive so I got it sorted now. I've tested a couple ofd Blurays, and they've copied fine.
@Sayaka: Yeah, I meant the 43888, my sausage fingers are stupid these days, my user name was supposed to have in it Hippo not Hippp.
So what I get from that is basically just copy the files from the disc and play as a file, or ensure that the software isn't region locking enabled, for want of a better way of putting it. Although I never really understood Region settings for DVD/Bluray, because it's not like it's being done to comply with distribution contracts, as the regions always span multiple countries, and multiple laws, languages, PAL/NTSC/Secam etc. It's good that UHD "seems" to have dropped it
Once again, thanks for the replies folks.
mrozkarol@yahoo.com
Post by mrozkarol@yahoo.com »
Hi, thanks for sharing your experience. Could you please post the link to the YouTube tutorial you used for flashing the firmware on the Verbatim drive?
I’m looking for a step-by-step guide for this specific drive, as the firmware flashing process can be a bit confusing and I’d rather follow a tested method.
mrozkarol@yahoo.com wrote: Tue Jul 28, 2026 8:08 am Hi, thanks for sharing your experience. Could you please post the link to the YouTube tutorial you used for flashing the firmware on the Verbatim drive?
See guide below
Treat it as a bu40n if it is.
Or email me or Marty for the auto flasher
