Post
by Billycar11 » Thu Jul 16, 2026 1:48 am
MelonIon wrote: Wed Jul 15, 2026 11:51 pm
hey, i got a bdr-209m on a tri-boot mac pro 5,1.
the drive works well and plays blu-rays (not uhds) efficiently on both
macos with the macgo bluray player and win10 with the makemkv+vlc workaround,
however, i havent managed to make it work on ubuntu.
was wondering of the functionalities gained by flashing the drive with your fw packages
and if it would retain full compatibility with the oses (id appreciate some help with the ubuntu situation)
and finally, your recommendations regarding bluray/uhd player/bdxl burner apps for all oses.
thanks!
Sure email me your makemkv drive info section see below for email
only benefit to the fw is it will also do UHD the rest is all just config for having makemkv integration on linux work
titanofwar
Post
by titanofwar » Sun Jul 19, 2026 12:21 am
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E114
Serial number:
Firmware date: 2017-12-21
Drive platform: RS8601
Firmware version: E114/ID71
Does this drive support UHD ? if so will i be able to do the firmware change on Linux ?
Post
by Billycar11 » Sun Jul 19, 2026 2:17 pm
titanofwar wrote: Sun Jul 19, 2026 12:21 am
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E114
Serial number:
no need to post your info publicly just email me directly
see below for email
flasher is windows only but you can use a vm
works on linux after flashing
jonbitzen
Post
by jonbitzen » Fri Aug 28, 2026 7:59 pm
Is there a way to cross-flash my drive to be able to read UHD discs? I have the following info from MakeMKV:
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.31
Serial number:
Firmware date: 2015-05-25
Drive platform: RS8600
Firmware version: 1.31
Post
by Coopervid » Sun Aug 30, 2026 4:35 pm
jonbitzen wrote: Fri Aug 28, 2026 7:59 pm
Revision: 1.31
Serial number:
PM sent.
Post
by Billycar11 » Mon Aug 31, 2026 12:03 am
Revision: 1.31
Serial number:
see below for email
kraath
Post
by kraath » Sat Sep 05, 2026 4:49 pm
Well I got a few of these fullsize 5,25. On official firmware they can`t do 4k.
Can you really just flash them to enable that mode?
OS device name: H:
Current profile: CD-ROM
Product: BD-RW BDR-209D
Revision: 1.51
Serial number: nope
Firmware date: 2018-05-08
Bus encryption flags: 13
Highest AACS version: 64
Firmware version: 1.51/ID61
Post
by Coopervid » Sat Sep 05, 2026 9:05 pm
kraath wrote: Sat Sep 05, 2026 4:49 pm
OS device name: H:
Revision: 1.51
Serial number: nope
PM sent.This is for 8600only. 8601 needs diffrent firmware.
Post
by Billycar11 » Sun Sep 06, 2026 12:14 am
OS device name: H:
Revision: 1.51
Serial number: nope
Sure email me that drive info section see below for email
All other no need to post your drive info publicly here just email directly for a faster response so you have to wait for fourm approval
fjjwfp
Post
by fjjwfp » Fri Sep 11, 2026 2:46 pm
Hi all, I have a BDR209 with the following info, can someone help with flashing it to enable 4k reading please? Thank you very much!
OS device name: G:
Revision: 1.51
Serial number:
Highest AACS version: 82
Firmware version: 1.51/ID60
Post
by Coopervid » Fri Sep 11, 2026 5:16 pm
fjjwfp wrote: Fri Sep 11, 2026 2:46 pm
OS device name: G:
Revision: 1.51
Serial number:
PM sent.
Post
by Billycar11 » Fri Sep 11, 2026 9:22 pm
OS device name: G:
Revision: 1.51
Serial number:
