Pioneer bdr 209 and Pioneer bdr 209m
Re: Pioneer bdr 209 and Pioneer bdr 209m
#226 Post by Billycar11 » Thu Jul 16, 2026 1:48 am
MelonIon wrote: Wed Jul 15, 2026 11:51 pm hey, i got a bdr-209m on a tri-boot mac pro 5,1.
the drive works well and plays blu-rays (not uhds) efficiently on both
macos with the macgo bluray player and win10 with the makemkv+vlc workaround,
however, i havent managed to make it work on ubuntu.
was wondering of the functionalities gained by flashing the drive with your fw packages
and if it would retain full compatibility with the oses (id appreciate some help with the ubuntu situation)
and finally, your recommendations regarding bluray/uhd player/bdxl burner apps for all oses.
thanks!
Sure email me your makemkv drive info section see below for email
only benefit to the fw is it will also do UHD the rest is all just config for having makemkv integration on linux work
titanofwar
#227 Post by titanofwar » Sun Jul 19, 2026 12:21 am
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E114
Serial number:
Firmware date: 2017-12-21
Drive platform: RS8601
Firmware version: E114/ID71
Does this drive support UHD ? if so will i be able to do the firmware change on Linux ?
#228 Post by Billycar11 » Sun Jul 19, 2026 2:17 pm
titanofwar wrote: Sun Jul 19, 2026 12:21 am Drive Information
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E114
Serial number:
no need to post your info publicly just email me directly
see below for email
flasher is windows only but you can use a vm
works on linux after flashing
