Blu-ray Captain America will not mount
kfreeb
Post by kfreeb »
My Blu-ray of Captain America will not mount. It cycles in the drive for about 2 minutes and then reports to Make MKV that there is no disk in the drive. Disk never mounts on desktop. This is the first Blu-ray disk that has failed to mount.
[Disk will mount in regular set top player, (Samsung) connected to flat panel TV.]
Here's my configuration:
Mac Pro 3GHZ
Blu-ray drive, connected via firewire through a Wiebetech Ultradock v4 bridge.
Drive Model: LG WH10LS30, (ROM ver. 1) Manufactured May 2010
Has anyone with the same drive, been able to mount this disk?
Any insight would be helpful.
Mac Studio M3 Ultra
96GB Memory
GPU 80 Core
CPU 24 Core
Sequoia 15.7.4
Romansh
Re: Blu-ray Captain America will not mount
Post by Romansh »
Have you tried launching MakeMKV first, and then inserting the disc in the drive?
kfreeb
Post by kfreeb »
Yes, still the disk will not mount. Not sure what is happing here. It's the only BD disk that will not mount, out of the many that I own.
Mac Studio M3 Ultra
96GB Memory
GPU 80 Core
CPU 24 Core
Sequoia 15.7.4
crowfax
Post by crowfax »
If your computer can't even see the disc there isn't much chance of anything opening it. Sounds like a defective disc, swap it for a new one disc.
kfreeb
Post by kfreeb »
I just had the disk resurfaced, cleaned up any blemishes in the surface and now the disk mounts just fine. I'm ripping it right now and looks like it will finish with no problems.
Thanks for all who responded, it's appreciated.
Mac Studio M3 Ultra
96GB Memory
GPU 80 Core
CPU 24 Core
Sequoia 15.7.4
