LibreDrive for Pioneer drives
Miromoon wrote: Sat Jul 18, 2026 3:35 am Hello,
I would like to know if my drive can be cross-flashed for UHD Blu-ray reading and which firmware is recommended.
Drive Information:
- Drive: ASUS SBW-06D5H-U
- Platform: RS8511
- Firmware name: PIONEER BDR-US03
- Firmware version: E101/ID26
- Firmware type: Original (unpatched)
- Firmware date: 2018-08-22
LibreDrive Information:
- Status: Enabled
- DVD all regions: Yes
- BD raw data read: Yes
- BD raw metadata read: Yes
- Unrestricted read speed: Yes
My UHD Blu-ray discs are currently not recognized, while regular Blu-ray discs work.
Could you please check whether this specific drive is compatible with the available UHD firmware and advise which firmware/tool should be used?
Thank you very much for your help.
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
Drive Information:
- Platform: RS8511
- Status: Enabled
PM is coming- if the forum works!
ZXG2109
Post by ZXG2109 »
Apologies if this is not the right information I am to post.
ZXG2109 wrote: Mon Jul 20, 2026 3:12 am Apologies if this is not the right information I am to post.
see below for email
agent_x007
Post by agent_x007 »
Hello
I managed to get a bit newer version of UD02D Pioneer drive (HW:1.02, SW:1.02).
Here's how sticker on top looks like (BDR-UD02DTBD) :
I attach it's capabilities to this message :
Would like to dump it's firmware before flashing, but so far no program I tried allows that :/
Any ideas ?
Eventually, I want to libredrive it, and (if possible) make it into UD03/UD04 4k capable drive (assuming a bit newer hardware revision allows that ?)
Thank you
agent_x007 wrote: Tue Jul 21, 2026 1:34 pm Hello
Any ideas ?
Thank you
might be able to be flashed to ud04 to do UHD
see below for email
agent_x007
Billycar11 wrote: Tue Jul 21, 2026 1:44 pm might be able to be flashed to ud04 to do UHD
see below for email
OS device name: H:
Manufacturer: PIONEER
Product: BD-RW BDR-UD02D
Revision: 1.02
Serial number: NCDL107266WL
Firmware date: 2014-02-10
Drive platform: Pioneer RS8410
Firmware version: ID84
