PM sent.diablobobo wrote: Thu Jul 16, 2026 3:19 am Hi Coopervid,
I also got a Pioneer BDR-XS07 with Firmware 1.01.
Can you please send me a PM with the Informations to upgrade?
Thank you so much![]()
BDR-XS07S UHD Flash
Re: BDR-XS07S UHD Flash
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
see below for email
Excalibur-CH
I have also a
Firmware version: 1.01/ID05
with a FW version date 03. Sept. 2020. So far, I haven't had an issue with ripping 4K movies onto my hard drive. But Mortal Kombat II (2026 version) is refusing to get ripped. MakeMKV complains, it is missing decryption key, passkey doesn't work with my Pioneer BD drive at all.
Do I really have to put in different FW or is it only this specific movie? If the recommendation is, to use different FW, can someone please DM me the instructions for it?
Thank you in advance.
Ps. I am ripping the movies to watch the 4k versions on my computer and this is the only way to do it.
If MakeMKV says it is missing a decryption key, then it undoubtedly produced a dump file. Attach that .tgz file to an email and send to svq@makemkv.com. Eventually a hashed key will be made that MakeMKV can download and decrypt the disc in question. There are more details in the UHD FAQ.Excalibur-CH wrote: Thu Jul 23, 2026 6:11 am I have also a
Additionally, MakeMKV can use the Public KeyDB. The necessary decryption key might already be there, but if not the dump file can be submitted there are well.
If your drive works for other 4K discs you should not need to change the firmware on your drive.
Excalibur-CH
I have sent the dump file about 7 days ago already and it will be automatically uploaded, each time MakeMKV fails to read the disk.. As such, I am currentl "spamming" them with dump files
But the public key works.. ripping as I write this.
caden
I also have the BDR-XS07S with fw 1.01 I'd like to update it's firmware. Thanks alot.
Manufacturer: PIONEER
Product: BD-RW BDR-XS07
Revision: 1.01
Serial number: [Redacted]
Firmware date: 2020-09-03
Bus encryption flags: 13
Highest AACS version: 63
Drive platform: RS8E20
Julzfreezz
Well I also got a BDR-XS07TS laying around.
Unfortunately I can´t PM you guys directly.
Could you give me the Information how to Crossflash the Firmware and which Firmware I have to use?
@Billycar11 and @Coopervid
Would be awesome!
Laufwerksinformation
OS-Gerätename: H:
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-XS07
Revision: 1.01
Serienummer: BFDL006504WL
Firmware-Datum: 2020-09-03
Markierungen der Bus-Verschlüsselung: 13
Highest AACS version: 81
Unrestricted read speed: YesCould you give me the Information how to Crossflash the Firmware and which Firmware I have to use?
Would be awesome!
PM sent.caden wrote: Sun Jul 26, 2026 12:49 pm I also have the BDR-XS07S with fw 1.01 I'd like to update it's firmware. Thanks alot.
Drive Information OS device name: D: Manufacturer: PIONEER Product: BD-RW BDR-XS07 Revision: 1.01 Serial number: [Redacted] Firmware date: 2020-09-03 Bus encryption flags: 13 Highest AACS version: 63 LibreDrive Information Status: Enabled Drive platform: RS8E20 Firmware name: PIONEER BDR-BDS7 Firmware type: Original (unpatched) Firmware version: 1.01 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
PM sent.Julzfreezz wrote: Sun Jul 26, 2026 4:48 pm Well I also got a BDR-XS07TS laying around.
Unfortunately I can´t PM you guys directly.Code: Select all
Laufwerksinformation OS-Gerätename: H: Aktuelles Profil: BD-ROM Produzent: PIONEER Produkt: BD-RW BDR-XS07 Revision: 1.01 Serienummer: BFDL006504WL Firmware-Datum: 2020-09-03 Markierungen der Bus-Verschlüsselung: 13 Highest AACS version: 81 LibreDrive Information Status: Enabled Drive platform: RS8E20 Firmware name: PIONEER BDR-BDS7 Firmware type: Original (unpatched) Firmware version: 1.01 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Would be awesome!
Streamline
Hi Coopervid,
I recently purchased a Pioneer BD-RW BDR-XS07 and would like to flash it with LibreDrive firmware to enable UHD Blu-ray reading capabilities. I understand from this thread that you've been helping others with the process, so I was wondering if you could kindly share the firmware files and instructions.
Below is my current MakeMKV drive information:
OS device name: G:
Revision: 1.01
Serial number: -
Could you please send me the firmware file and flashing instructions via private message? I'll follow the guidelines carefully and take appropriate precautions during the process.
I appreciate your time and the community effort you're providing. Thank you very much!
Best regards,
Streamline
OS device name: G:
Revision: 1.01
Serial number: -
Best regards,
Streamline
Streamline wrote: Sun Jul 26, 2026 6:41 pm Hi,Julzfreezz wrote: Sun Jul 26, 2026 4:48 pm Well I also got a BDR-XS07TS laying around.
Would be awesome!
OS device name: G:
Revision: 1.01
Serial number: -
Best regards,
Streamline
sure email me that info andcaden wrote: Sun Jul 26, 2026 12:49 pm I also have the BDR-XS07S with fw 1.01 I'd like to update it's firmware. Thanks alot.
all others email me no need to post your info here publicly just reach out to me directly
see below for email
Julzfreezz
Haven´t figured out how to reply on the pm but it worked perfectly!! Thanks alot!Coopervid wrote: Sun Jul 26, 2026 5:32 pmPM sent.Julzfreezz wrote: Sun Jul 26, 2026 4:48 pm Well I also got a BDR-XS07TS laying around.
Would be awesome!
EM2230
BDR-XS07SU UHD Flash
I would also like to get my drive done please
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number: CKDL016060UC
Firmware date: 2023-01-06
Highest AACS version: 77
Drive platform: RS8E21
Firmware version: 1.03/ID05
Revision: 1.03
PM sent.Streamline wrote: Sun Jul 26, 2026 6:41 pm Hi Coopervid,
OS device name: G:
Revision: 1.01
Serial number: -
Best regards,
Streamline
Re: BDR-XS07SU UHD Flash
your drive does not need to be flashedEM2230 wrote: Sat Aug 01, 2026 4:41 pm I would also like to get my drive done please
Revision: 1.03
if you need support email below
