DarkCity - Copy complete. 2 titles saved, 1 failed.
brucex
Post by brucex » Thu Apr 26, 2012 1:58 am
The main track fails. Log attached (sorry about double upload - one didn't seem to work). Any advice as to settings I can try or is MakeMKV failing?
I successfully ripped it using DVDFab so the disc is fine.
I have been successful with other DVDs (terrific program BTW).
thanks
Bruce
MakeMKV_log.zip
(16.21 KiB) Downloaded 359 times
MakeMKV_log.txt
(473.75 KiB) Downloaded 341 times
Re: DarkCity - Copy complete. 2 titles saved, 1 failed.
Post by mike admin » Tue May 01, 2012 8:24 am
This looks like a bug in MakeMKV. In order to properly troubleshoot it, I have to ask you to do a lengthy step - please submit a test dump for the main title per instructions at http://www.makemkv.com/onlinehelp/testdump.html .
brucex
Post by brucex » Mon May 07, 2012 2:59 am
Hi Mike
Tried this when only selecting the failing track. I tried the *TESTDUMP* setting
immediately after loading MakeMKV and, after reloading the program, after
loading the DVD but just before pressing the Make MKV button. No difference.
Used administration mode (Win7).
No file is produced at all. Attached the log.
When I tried with all tracks, I got title01.tgz and title02.tgz. No title00.tgz which
is the track with the problem.
I am using 1.7.4 Beta.
thanks
MakeMKV_log.txt
(22.66 KiB) Downloaded 387 times
