BU40N with "GC02" firmware, flashes report success but never commit
NahalielBriathos
#1 Post by NahalielBriathos » Wed Jul 15, 2026 1:03 pm
Has anyone manage to flash a BU40N with the GC02 firmware? Every time that I try, it never commits.
Every flash attempt with 1.03MK reports full success via makemkvcon rawflash/enc on Linux. After every cold boot, makemkvcon -l still reports GC02, unchanged.
Drive ID: HL-DT-ST_BD-RE_BU40N_GC02_211801310916_KZBI5NB5212
Any help is greatly appreciated
Re: BU40N with "GC02" firmware, flashes report success but never commit
#2 Post by Billycar11 » Wed Jul 15, 2026 1:23 pm
Likely no enc
See guide below
Or email me or Marty for an automated flasher.
See below for email
NahalielBriathos
#3 Post by NahalielBriathos » Wed Jul 15, 2026 8:13 pm
Here is the complete command that I ran:
LD_LIBRARY_PATH=../lib ./makemkvcon f -d /dev/sr0 -f sdf.bin rawflash enc -i HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Reading input file HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Current Drive ID: HL-DT-ST_BD-RE_BU40N_GC02_211801310916_KZBI5NB5212
yes
 100% Operation finished
Done successfully
After a reboot I did:
LD_LIBRARY_PATH=../lib ./makemkvcon f -l
Found 1 drives(s)
00: dev_21:0, /dev/sr0, /dev/sr0
GC02 persisted.
#4 Post by MartyMcNuts » Wed Jul 15, 2026 10:49 pm
NahalielBriathos wrote: Wed Jul 15, 2026 8:13 pm Here is the complete command that I ran:
yes
Done successfully
Found 1 drives(s)
GC02 persisted.
No ENC!!! rawflash main
NahalielBriathos
#5 Post by NahalielBriathos » Wed Jul 15, 2026 11:49 pm
That worked, thank you!
My bad.. I thought you meant that I tried the command without the enc param when you said no enc.. should've read the guide more carefully.
