BU40N with "GC02" firmware, flashes report success but never commit
NahalielBriathos
Post by NahalielBriathos »
Has anyone manage to flash a BU40N with the GC02 firmware? Every time that I try, it never commits.
Every flash attempt with 1.03MK reports full success via makemkvcon rawflash/enc on Linux. After every cold boot, makemkvcon -l still reports GC02, unchanged.
Drive ID: HL-DT-ST_BD-RE_BU40N_GC02_211801310916_KZBI5NB5212
Any help is greatly appreciated
Re: BU40N with "GC02" firmware, flashes report success but never commit
Likely no enc
See guide below
Or email me or Marty for an automated flasher.
See below for email
NahalielBriathos
Here is the complete command that I ran:
LD_LIBRARY_PATH=../lib ./makemkvcon f -d /dev/sr0 -f sdf.bin rawflash enc -i HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Reading input file HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Current Drive ID: HL-DT-ST_BD-RE_BU40N_GC02_211801310916_KZBI5NB5212
yes
 100% Operation finished
Done successfully
After a reboot I did:
LD_LIBRARY_PATH=../lib ./makemkvcon f -l
Found 1 drives(s)
00: dev_21:0, /dev/sr0, /dev/sr0
GC02 persisted.
NahalielBriathos wrote: Wed Jul 15, 2026 8:13 pm Here is the complete command that I ran:
yes
Done successfully
Found 1 drives(s)
GC02 persisted.
No ENC!!! rawflash main
NahalielBriathos
That worked, thank you!
My bad.. I thought you meant that I tried the command without the enc param when you said no enc.. should've read the guide more carefully.
