BP71N crossflashed to BU40N and cannot be downgraded
ij478
Post by ij478 » Tue Jul 14, 2026 8:41 am
I recently bought a UGREEN UHD drive that is a BP71N which looks like a BU40N rebranded. It comes with 1.03 unpatched. So I flashed the HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin firmware as provided by mike.
But after that I'm unable to downgrade to any other firmware such as BU40N-1.03 or even DE_LG BU40N_1.00.bin in Downgrade firmware pack. After flashing the firmware just sticks at 1.04. I have tried either adding "enc" and "de" after "rawflash" but none of them works. What should I do? :(
the first flash:
./makemkvcon f -f '/home/xiaoxi/Downloads/mk-firmware-pack-20200720/MK/sdf.bin' -d /dev/sr0 rawflash enc main -i '/home/xiaoxi/Downloads/mk-firmware-pack-20200720/MK/HL-DT-ST/BU40N-N-Main/HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin'
one of the failed flashes:
./makemkvcon f -d /dev/sr0 rawflash enc -i '/home/xiaoxi/Downloads/mk-firmware-pack-20200720/MK/old/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin'
ij478
Re: BP71N crossflashed to BU40N and cannot be downgraded
Post by ij478 » Tue Jul 14, 2026 9:29 am
ALRIGHT! I fixed it!
By using the SDFTool flasher and checking how it flashes, I successfully flashed this drive.
In a word, after crossflashing, you need to manually specify the boot code.
Here is the complete flash code:
./makemkvcon f -f '/home/xiaoxi/Downloads/mk-firmware-pack-20200720/MK/sdf.bin' -d /dev/sr0 rawflash boot="MT1959 Boot BU5 " -i '/home/xiaoxi/Downloads/Downgrade Enabled Firmware V.2/DE_LG BU40N_1.00.bin'
Sayaka
Post by Sayaka » Tue Jul 14, 2026 1:27 pm
Instead of flashing BU40N 1.04-MK, you should have flashed BU40N 1.03-MK right away (and then possibly BU40N 1.00 without "enc"). Congratulations on figuring out how to fix the issue you were having. :wink:
ij478
Post by ij478 » Tue Jul 14, 2026 1:43 pm
Sayaka wrote: Tue Jul 14, 2026 1:27 pm Instead of flashing BU40N 1.04-MK, you should have flashed BU40N 1.03-MK right away (and then possibly BU40N 1.00 without "enc"). Congratulations on figuring out how to fix the issue you were having. :wink:
Yes. It was my fault thinking "newer is better". Now I choose to stick to 1.00 which can use both qpxtool and LibreDrive.
