Makemkv 1.18.3 Win XP error message
gkar_of_narn
Post by gkar_of_narn »
Makemkv 1.18.3 on Windows XP 32 bit
"The procedure entry point swprintf_s could not be located in the dynamic link library msvcrt.dll" error message on first launch after install.
gkar_of_narn
Re: Makemkv 1.18.3 Win XP error message
Same message appears on 1.18.4...."The procedure entry point swprintf_s could not be located in the dynamic link library msvcrt.dll"...Windows XP x86
AstralWanderer
Post by AstralWanderer »
Please review the Makemkv on Win XP thread for a fix for this.
gkar_of_narn
Please note MakeMKV 1.18.2 works. It started tanking on 1.18.3. All 4 of my WinXP x86 boxes have this problem. I searched for the error message and tried the various solutions to no avail. I'll look over your solutions. Thank you.
(Please also note I use WinXP x86 offline only to run all my old software. I use only my Linux Mint Debian Edition 7 boxes when online.)
gkar_of_narn
Since this version doesn't work (like the previous two versions) with Windows XP X86 I'll assume it has been deprecated as has been warned within the working versions. Looks like 1.18.2 is the version I'll be using. The X86 version support ought to be pulled from the download area.
gkar_of_narn
No responses by the makemkv team to a purchaser of makemkv quite a while back. Not good.
gwhitcombe71
Post by gwhitcombe71 »
gkar_of_narn, out of curiosity... did you try the fix in that Win XP thread on all four boxes, or just the one? and did 1.18.2 go on clean each time, or did you have to fiddle with msvcrt.dll (or anything else) first? cheers
