Dumps Submitted - Stranger Things - Arrow UK Release
Bluntmad
Post by Bluntmad » Fri Jul 10, 2026 4:06 pm
Season 1 Discs 1 - 3
MKB20_v82_STRANGER_THINGS_SEASON1_DISC1_13F4.tgz
MKB20_v82_STRANGER_THINGS_SEASON1_DISC2_F41A.tgz
MKB20_v82_STRANGER_THINGS_SEASON1_DISC3_4A32.tgz
Season 2 Discs 1 - 3
MKB20_v82_STRANGER_THINGS_SEASON2_DISC1_FD12.tgz
MKB20_v82_STRANGER_THINGS_SEASON2_DISC2_4B72.tgz
MKB20_v82_STRANGER_THINGS_SEASON2_DISC3_9018.tgz
Dumps can be found here : https://drive.google.com/drive/folders/ ... drive_link
will post again if I get to the remaining discs tonight.
Bluntmad
Re: Dumps Submitted - Stranger Things - Arrow UK Release
Post by Bluntmad » Fri Jul 10, 2026 5:01 pm
Season 3 Discs 1 - 3
MKB20_v82_STRANGER_THINGS_SEASON3_DISC1_BF1C.tgz
MKB20_v82_STRANGER_THINGS_SEASON3_DISC2_34FE.tgz
MKB20_v82_STRANGER_THINGS_SEASON3_DISC3_A048.tgz
Bluntmad
Post by Bluntmad » Fri Jul 10, 2026 5:14 pm
Season 4 Discs 1 - 6
MKB20_v82_STRANGER_THINGS_SEASON4_DISC1_83F0.tgz
MKB20_v82_STRANGER_THINGS_SEASON4_DISC2_6E26.tgz
MKB20_v82_STRANGER_THINGS_SEASON4_DISC3_BAE8.tgz
MKB20_v82_STRANGER_THINGS_SEASON4_DISC4_F520.tgz
MKB20_v82_STRANGER_THINGS_SEASON4_DISC5_F85A.tgz
MKB20_v82_STRANGER_THINGS_SEASON4_DISC6_DB7E.tgz
Bluntmad
Post by Bluntmad » Fri Jul 10, 2026 5:56 pm
Season 5 Discs 1 - 5
MKB20_v82_STRANGER_THINGS_SEASON5_DISC1_743C.tgz
MKB20_v82_STRANGER_THINGS_SEASON5_DISC2_423A.tgz
MKB20_v82_STRANGER_THINGS_SEASON5_DISC3_41FE.tgz
MKB20_v82_STRANGER_THINGS_SEASON5_DISC4_EACC.tgz
MKB20_v82_STRANGER_THINGS_SEASON5_DISC5_9A2E.tgz
trashraccoon
Post by trashraccoon » Sat Jul 11, 2026 5:25 am
Thanks for these.
I submitted them to the community maintained KeyDB yesterday and they've been added. If you have KeyDB setup you are good to go.
Bluntmad
Post by Bluntmad » Sat Jul 11, 2026 6:58 am
These are now ripping as of this morning. Thanks to @trashracoon for forwarding the my link to the public key submission thread.
trashraccoon
Post by trashraccoon » Sun Jul 12, 2026 7:53 am
Heads up, I found that Season 2 Disc 2 had an AACS folder but was not actually copy protected which caused MakeMKV to hang while scanning the disc.
To fix this make a backup of the disc; delete the AACS folder; open the backup in MakeMKV & continue as normal.
bobbydazz
Post by bobbydazz » Mon Jul 13, 2026 8:09 pm
trashraccoon wrote: Sun Jul 12, 2026 7:53 am Heads up, I found that Season 2 Disc 2 had an AACS folder but was not actually copy protected which caused MakeMKV to hang while scanning the disc.
Thanks, I've been scratching my head on this for a couple days now, I don't usually buy new discs so haven't had this issue before.
VarHD
Post by VarHD » Wed Jul 15, 2026 2:30 pm
Submitting MKB20_v82_STRANGER_THINGS_SEASON2_DISC2_4B72.tgz since that one still can't be decrypted on my end.
pitmanj
Post by pitmanj » Wed Jul 15, 2026 8:03 pm
VarHD wrote: Wed Jul 15, 2026 2:30 pm Submitting MKB20_v82_STRANGER_THINGS_SEASON2_DISC2_4B72.tgz since that one still can't be decrypted on my end.
Same for me on my end can't even try to backup like someone said to try as that fails also
VarHD
Post by VarHD » Thu Jul 16, 2026 1:08 pm
Oh wow, it worked! I mean the workaround - backup without decrypting, then deleting the AACS folder and that's it, it's actually not encrypted :lol:
BTW, the same issue seems to affect Season 4 Disc 3 and Season 5 Disc 2, and the same "solution" works here (at least for me).
All this time I've been ripping movies, I've never seen... stranger things happen ;)
pitmanj
Post by pitmanj » Thu Jul 16, 2026 9:32 pm
I can't even get it to backup it fails mid way through on the disc mentioned. What am i doing wrong
Carnivalius
Post by Carnivalius » Fri Jul 17, 2026 10:24 am
Might be a silly reply, but did you untick "decrypt video" option when backing up the disc? It didn't work properly until I did that myself.
pitmanj
Post by pitmanj » Fri Jul 17, 2026 8:37 pm
Carnivalius wrote: Fri Jul 17, 2026 10:24 am Might be a silly reply, but did you untick "decrypt video" option when backing up the disc? It didn't work properly until I did that myself.
You were not silly asking. Before I updated the keydb.cfg file i tried both of these ways and no dice.
Then when I had that updated I forgot to uncheck decrypt video. It appears to be working so far now.
Scarbz
Post by Scarbz » Tue Jul 28, 2026 4:14 pm
Guys what size dose the complete sessions end up being. Need to work out hdd space.
Thank you for any help
