Drive Kit 1.0 - pioneer flasher
babayaga
Post by babayaga » Fri Jul 10, 2026 3:26 pm
I've made a flasher for pioneer drives, basically i'ts a easy mod, problem is having all the current firmwares for crossflashing. Im not going to release the firmwares, as long as im not allowed to, but i want this project to be open source and can be further upgraded, and also ported to linux, even though i have used windows heavily in the development, this is the about information about the flasher, i can share code with people that are interessted in actually helping out coding. I also have autoflash function, but still its not, because im afraid of bricking drives, so there are a few questions before flashing actually commence. This is the about file, contact me if you want to be developing for it, and that we can make it open source in time! :)
C:\firmware>drivekit about
     █░██ ██░▌ Drive Kit v1.0           cPix / Razor 1911 (c) 2026
     █░██■██▀  Optical drive research toolkit
=== ABOUT DRIVEKIT ===
  DriveKit is an optical drive research toolkit focused on
  Pioneer BD optical drives. It allows firmware flashing,
  drive identification, SCSI command probing and firmware
  analysis of Pioneer BD-R/BD-RE drives.
  Research & Development
  The flash protocol was reverse engineered by capturing
  USB traffic between BDRFlash and Pioneer drives using
  Wireshark/USBPcap. Key findings include:
  - WRITE BUFFER mode=4 bufID=0xFF unlock sequence
  - Model string + key payload format
  - READ BUFFER 0xB0 kernel mode trigger bug
  - Drive family compatibility groups
  - Serial number manufacture date/country decode
    (full country table vs BDRFlash hardcoded China)
  Tools Used
  Wireshark + USBPcap  - USB traffic capture
  IDA Pro + Hex-Rays   - BDRFlash reverse engineering
  hrtng IDA plugin     - Decompilation assistance
  x64dbg               - Dynamic analysis and debugging
  MSVC (cl.exe)        - Compilation
  Credits
  blackened2687        - BDRFlash / AutoFlasher author
                         Pioneer flash protocol pioneer :)
  MakeMKV community    - Drive testing and research
  rpc1dev              - DVRFlash open source reference
  Hardware Research
  Pioneer BD drives use the Renesas R8J32740 optical drive
  controller (confirmed via BDR-XD08 teardown). Firmware
  decompilation confirmed ARM Thumb-2 (ARMv6) instruction
  set compiled with GNU C++. No public datasheet exists for
  this custom Pioneer/Renesas OEM chip family. DriveKit is
  believed to be the first tool to document the R8J32740
  memory map and peripheral register layout through firmware
  analysis (ROM at 0xFF000000, peripherals at 0xFFFF1000).
  DriveKit v1.0 - cPix / Razor 1911 (c) 2026
   Razor 1911   /__\   Since 1985
                    /__\/__\
C:\firmware>
as i said, at this point its closed source because there are legal issues around this, but do pioneer really care anymore? :P
these are all commands it takes at the moment, but remember, its a lot of debug commands which doesn't make this util EASY for newbies.
Usage:
  drivekit <command> <drive_letter> [options]
Commands:
  inquiry       Read drive identity
  driveinfo     Full drive feature probe and profile list
  bdread        Query MMC feature 0x010C (BD Read)
  modepage      Dump mode page 0x2A (drive capabilities)
  probef0       Probe READ BUFFER IDs 0xF0-0xFF
  rawdump       Raw READ BUFFER dump
  combinedump   Dump 0xF4+0xFE into one combined file
  findsigs      Scan a file for firmware signatures
  unlock        Pioneer RS8801 service mode unlock
  resetdrive    Reset an unresponsive SATA drive
  probevendor   Probe vendor opcodes 0xC0-0xFF
  mt1959        HLDS/LG MT1959 probe
  discinfo      Read and parse BD/DVD disc information
  discstruct    READ DISC STRUCTURE (0xAD)
  probeb0       Read/decode RS8801 buffer 0xB0
  modelcheck    Pioneer model lookup
  keycheck      Vendor unlock key lookup
  probewb       Probe WRITE BUFFER modes/lengths for unlock
  brutekey      Try all known Pioneer keys to find correct one
  extract       Extract firmware blobs from BDRFlash.exe
  getresource   Extract kernel resources 131/132 from BDRFlash.exe
  autoflash     Auto-detect and flash firmware from firmware\ folder
                (detects Pioneer firmware by content, any filename)
  flashfw       Flash kernel+firmware to drive (NO disc!)
  sendfirmware  Send main firmware image (bufID=0xF0)
  triggerkernel Single READ 0xB0 trigger to enter kernel mode
  dumpfw        Trigger kernel mode and dump firmware (disc required)
  checkfw       Check drive firmware against drives.json database
  fwversion     Build BDRFlash-style firmware version string
  resetnormal   Return drive from kernel mode to normal mode
  about         About DriveKit and credits
Options:
  --bufid 0xF4  Buffer ID for rawdump (default 0xF4)
  --file  name  Output filename override
Examples:
  drivekit inquiry G
  drivekit unlock G
  drivekit brutekey G
  drivekit rawdump G --bufid 0xF4
  drivekit probef0 G
  drivekit findsigs firmware.bin
Note: Run as Administrator for drive access.
best regards,
babayaga.
sharpening the blade since 1985... ;)
tomty89
Re: Drive Kit 1.0 - pioneer flasher
Post by tomty89 » Fri Jul 10, 2026 3:39 pm
I feel like some people might not like it for the fact that the development involved reverse engineering BDRFlash...
babayaga
Post by babayaga » Fri Jul 10, 2026 4:15 pm
tomty89 wrote: Fri Jul 10, 2026 3:39 pm I feel like some people might not like it for the fact that the development involved reverse engineering BDRFlash...
Yes, that i understand, but its freeware. im not releasing naything, and i got most cdbs from offical upgrades..
tomty89
Post by tomty89 » Sun Jul 12, 2026 3:26 am
I hope that this wouldn't sound offensive but I can't help but want to ask: in terms of like "layman interest" (i.e. getting a Pioneer drive crossflashed), is there currently any advantage of using this over BDRFlash? Or, does it aim at gaining one/some (e.g. "breakthrough" regarding post Dec 2022 firmware)? Or is it (going to be) more like a "universal tool that consist of a part that reimplements BDRFlash (with firmware "auto selection" -- a.k.a. autoflash?)"?
P.S. I guess what I was really trying to say is, it seems to me that the goal / focus of this project is unclear, but it's just the "judgemental reflex" of my brain got triggered, so don't mind me...
By the way, I just saw:
I don't think BDRFlash.exe has any firmware / kernel embedded?
babayaga
Post by babayaga » Sun Jul 12, 2026 6:24 am
tomty89 wrote: Sun Jul 12, 2026 3:26 am I hope that this wouldn't sound offensive but I can't help but want to ask: in terms of like "layman interest" (i.e. getting a Pioneer drive crossflashed), is there currently any advantage of using this over BDRFlash? Or, does it aim at gaining one/some (e.g. "breakthrough" regarding post Dec 2022 firmware)? Or is it (going to be) more like a "universal tool that consist of a part that reimplements BDRFlash (with firmware "auto selection" -- a.k.a. autoflash?)"?
keydb_helper
Post by keydb_helper » Mon Jul 13, 2026 3:01 am
babayaga wrote: Fri Jul 10, 2026 3:26 pm Pioneer BD drives use the Renesas R8J32740 optical drive
Your project sounds interesting babayaga but I'm not sure about this reference to ARMv6.
As I mentioned in May, my own experience reverse engineering and writing code for the R8J32740 has exclusively involved a variant of the H8S instruction set:
keydb_helper wrote: Thu May 07, 2026 8:06 am Hey babayaga, the modern Pioneer drives use a Renesas/Hitachi ISA. I'm not sure of the exact variant but it is pretty close to the H8S/2600.
IDA Pro can be used as a disassembler and there are out of tree plugins for Ghidra. If you'd like to use GNU binutils or GCC, the h8300s architecture is a solid choice for both (dis)assembly and compilation.
Is there a secondary ARMv6 chip within the Renesas SoC?
Public KeyDB Disc Submissions
babayaga
Post by babayaga » Tue Jul 14, 2026 3:08 am
keydb_helper wrote: Mon Jul 13, 2026 3:01 am
There was a external rom decamped hat confirmed this, but it can ha been used before, i don' know, Im only doing is project because i didn't go on holiday to day, i spent my money on a wEW TV :) I will still use bilicar fir then new drives and i know he has put al ot of money info this, I'm hot cheap. More than you saw i was looking for newer drivers with locked drives, i only want to probe the shit out of those drives and see what i can find :) there are a nuvh of vendor modes on the pioneer, i want to know what it is! That's the whole story. I am a assembler programmer and a i have a good knowledge of electronics, so it shohouldnæt be that hard.
Thee
babayaga
Post by babayaga » Tue Jul 21, 2026 12:52 am
You are right, there are no firmware og kernel embedded, i just had to search. The version i posted here on the forum is v1, and it contains tons of useless functions i used when i was debugging and trying to figure stuff out. I was a bit shocked that pioneer firmware is not patched or done anything with, but that they have a number of firmwares that are UHD compatible, and can be crossflashed. My goal is the same as billy, to flash a "new" drive, but not for money, i do this for fun. Im over half way coding a flasher for linux as well. :)
babayaga
Post by babayaga » Tue Jul 21, 2026 2:24 am
seems to be armv6 thumb 2
keydb_helper
Post by keydb_helper » Wed Jul 22, 2026 4:53 am
babayaga wrote: Tue Jul 21, 2026 2:24 am seems to be armv6 thumb 2
No, it is not any variant of ARM.
I am not speaking from assumptions based on which disassembler looks somewhat reasonable for a given binary. I have written a decent amount of code for the R8J32740 and I've spent a bit of time reverse engineering both firmware and microcode extensions for the platform.
These are not ARM chips. They use a variant of H8S.
babayaga
Post by babayaga » Mon Jul 27, 2026 8:09 am
keydb_helper wrote: Wed Jul 22, 2026 4:53 am
You are completely right, i was not reading 0xF4 nand encryption correctly, but 0xB0 was actually decrypteted and i could analyze the code in IDA with assembly there, big-endian H8S. B0 also has ppossible writebuffer, but im not too sure it's safe to do so, so i'll let that be for the moment. Pioneer BD drives (BDR-211M/SAT 8801 family) confirmed to use
Renesas H8S/2000 processor (big-endian 16/32-bit RISC).
Confirmed by decoding the 0xB0 READ BUFFER dump and
disassembling the firmware as H8S/2000 assembly.
Memory map (from H8S assembly):
0x00100000 = bootloader start
0x00400000 = main firmware start
0x00410000 = model string storage
0xFF414000 = physical address (via 0xB0 mapping)
TWO unlock keys confirmed from WRITE BUFFER handler:
0x6123789A = primary key (LE form of H8S 0x9A782361)
0x5CF2E094 = secondary key (LE form of H8S 0x94E0F25C)
Note: Earlier analysis suggested ARM Thumb-2 (ARMv6) based
on a decompiled C file. H8S/2000 is now confirmed correct
for the SAT 8801 family via direct assembly analysis.
babayaga
Post by babayaga » Mon Aug 17, 2026 7:56 pm
I'm a little bit socked that some people find this offensive, disassembly of a program in assembly should be legit enough, and also using all the tools i've been using to figure it all out should be OK! :) As long as wireshark and the official updaters are used to document the process it should be fine. I really didn't read any code in C or anything like that, i read every instruction and code by hand, some was done in a debugger (well, not makemkv, it had a hard encryption), but everything else. DVRFlash is out there on github, and bdrflash would be as well if it wasn't for legal issues, now he is working for billy and not giving anything out, which i think is bad, firmware patching shouldn't be a money based project - let's all remember c64eva providing the entire scene of xbox 360 firmware drives, he didn't earn a dime......... I'm a pirate, just like most of you.
inheavens
Post by inheavens » Wed Aug 19, 2026 11:56 pm
​Could you consider adding cross-flashing support for rarer hardware variants?
​For example, the drive mechanism inside the Sharp NW510 BD recorder is a Pioneer L12SH, which is essentially identical to the BDR-208M as well as pre-2018 BDR-209 and BDR-211 models. It would be great to have cross-flash support for these drives. The L12SH identifies with Hardware Type: REC 8900, ID 92.
​Lately, I’ve also been tinkering with some interesting Pioneer drives and rare Blu-ray media. Many of these discs aren't on Pioneer’s official MID whitelist, but they were actually manufactured in the same OEM fabs as officially supported media. For instance, discs from the defunct Amethyst Storage (MID: MTBS-IMK) can be successfully burned using the disc-swapping method under the VERBAT-IMK strategy, and AMESTB-RT4 burns reliably using RITEK-TL2. Using Pioneer drive mechanisms pulled from Sharp recorders to swap and burn these obscure discs has been a really fun project.
cxplay
Post by cxplay » Mon Aug 24, 2026 3:44 am
I don't think this is a suitable place to discuss driver firmware reverse engineering. Many enthusiasts have been forced here since some of the largest driver communities shut down without explanation. We need a new community for driver enthusiasts, not one that exists solely for ripping UHDs.
