Jackie Chan's Breakout Hits [Limited Edition] [4K Ultra HD] Box Set
NickFerg
Post by NickFerg »
I’m trying to rip the discs from this new release, but my drive cannot read them. The box set was just released, and I purchased it through Amazon, and when I insert them MakeMKV says that it’s reading the disc, and then after about two minutes it ejects it. I thought at first it might be a drive issue, so I updated the drive with the SDFtool flasher, and the drive shows it should work. Unfortunately, I don’t have any other UHD discs to test if the issue is with all UHDs, and DVDs and 1080p Blu-rays seem to work fine. I’m not sure what else I should include here, but I’ll include what MakeMKV showed for the drive before and after flashing. I have the log file and can post that as well, but it is fairly unhelpful since it never actually reads the disc. I'm on macOS, but I needed to use a Windows VM to patch the firmware and can re-patch that way if necessary. I've also seen some people having success using version 1.17.7 on Linux, but I'm not sure how to compile that for macOS. I guess I could go that direction and figure it out if necessary.
Here’s MakeMKV’s info pane:
BEFORE:
OS device name: /dev/rdisk6
Product: BD-RE BP50NB40
Revision: 1.03
Serial number: [redacted]
Highest AACS version: 68
Harware support: Yes
Firmware support: No
Firmware version: 1.03
AFTER:
OS device name: /dev/rdisk4
Revision: 1.03
Serial number: SIM2121145053
Disc Information
Label: [redacted]
Timestamp: 2020-11-10 17:24:21
Protection: AACS v68
Data capacity: 25.95 Gb
Disc type: BD-ROM
Number of layers: 2
And here’s the log:
Debug log started at Sat Jul 4 19:21:36 2026 , written by MakeMKV v1.18.4 darwin(arm64-release)
001005:0000 MakeMKV v1.18.4 darwin(arm64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///Users/nicholasferguson/MakeMKV_log.txt
Network access is ENABLED, CURL version 8.7.1/(SecureTransport) LibreSSL/3.3.6/1.69.0 (x86_64-apple-darwin26.0) , proxy server not set.
002010:0000 Optical drive "BD-RE HL-DT-ST BD-RE BP50NB40 1.03 SIM2121145053d" opened in OS access mode.
SDF v0a6: HL-DT-ST_BD-RE_BP50NB40_1.03_212005070917_SIM2121145053
And for clarification, the drive is a BP50NB40-NB50 which was flashed with that version of the patched firmware.
Any help is appreciated; thank you.
Re: Jackie Chan's Breakout Hits [Limited Edition] [4K Ultra HD] Box Set
I think a BP50NB40 is a two-hopper drive, meaning it has to be flashed twice to work with UHD.
Ultimate UHD Drives Flashing Guide
The 'Recommended Firmware to Flash for MakeMKV' section says:
WP/BP50NB40 to > BP50NB40-NB50-1.03MK then to > BP60NB10 1.02MK or 1.00MK
I would guess that you've done the first part and now need to cross flash it to the BP60NB10 firmware.
You can do this from Terminal in macOS if you like (the instructions are farther down in the Guide), or use SDFtool in a Windows VM.
NickFerg
Post by NickFerg »
You are 100% correct, I failed to complete the flashing process. Once I watched the gif in the SDFtool Flasher thread viewtopic.php?f=16&t=22896 I realized it, I was just a bit confused by the directions since they appeared to only apply to the NB52 and not the NB50. now that I followed the instructions the drive is working perfectly and ripping the UHD discs without issue. Thanks for the help dcoke22, and I hope if anyone else is experiencing this issue they'll find this thread helpful.
