Marcrevo
Post by Marcrevo »
Hello I currently have a Pioneer drive with 4UHK capabilities, however I would like assistance on how the drive can read and Rip 4K UHD discs.
OS device name: E:
Current profile: BD-R SRM
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.31
Serial number: PADL081160WL
Firmware date: 2015-05-25
Highest AACS version: 66
Drive platform: RS8600
Firmware version: 1.31
Disc Information
Label: TMNT_ OutOfShadows_3D
Timestamp: 2025-07-08 09:36:21
Data capacity: 22.58 Gb
Disc type: BD-R
Number of layers: 1
Collyde
Post by Collyde »
Billycar11 wrote: Wed Jul 08, 2026 9:46 pm
Collyde wrote: Wed Jul 08, 2026 6:38 pm I upgraded my BU40N a number of years ago.
The Drive and Libredrive report FW 1.01
Should I update to a later flash? What would I gain? Are there release notes?
-- Harald
ps I reflashed with /Applications/MakeMKV.app/Contents/MacOS/makemkvcon f -d /IOBDServices/E8BA6DA0 -f /tmp/sdf.bin rawflash enc -i /tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin - but the FW stayed at 1.01.
Remove enc
That worked. Thank you!
Cheers,
-- Harald
Marcrevo wrote: Thu Jul 09, 2026 3:30 am Hello I currently have a Pioneer drive with 4UHK capabilities, however I would like assistance on how the drive can read and Rip 4K UHD discs.
OS device name: E:
Revision: 1.31
Disc Information
Disc type: BD-R
Number of layers: 1
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
AstralWanderer
Post by AstralWanderer »
Recently flashed an LG BD-RE WH16NS58 drive to WH16NS60_1.02_MK without incident - thanks to those here who provided the tools, firmware and instructions.
However I did notice another benefit aside from LibreDrive. When I first installed the LG drive, I noticed immediately how much slower system startup became - this drive would spin up and stop (as if checking for a disk) twice during the BIOS startup screen and then twice more during Windows startup.
With the new firmware, the drive no longer spins up at all and this has cut about 30 seconds from my Windows startup times.
randomguy123
Post by randomguy123 »
I recently purchased a drive WP50NB40, svc code NB52, dumped the firmware as `dump_user_HL-DT-ST_BD-RE_WP50NB40_1.03_212107081609_.tar`
I'm looking to flash it, but this may not have a DE firmware available yet. Is this the right place to ask for help?
randomguy123 wrote: Wed Jul 15, 2026 11:28 pm I recently purchased a drive WP50NB40, svc code NB52, dumped the firmware as `dump_user_HL-DT-ST_BD-RE_WP50NB40_1.03_212107081609_.tar`
see post 1 or
email me or marty for an auto flasher
Sayaka
Post by Sayaka »
randomguy123 wrote: Wed Jul 15, 2026 11:28 pm dumped the firmware as `dump_user_HL-DT-ST_BD-RE_WP50NB40_1.03_212107081609_.tar`
By the way, there is virtually no point in doing this. The original firmware for your drive is encrypted, so only the user data got dumped. You will not be able to flash it back, because it's not a full backup of the original firmware.
Anyway, the only thing you need here is the All You Need Firmware Pack from MartyMcNuts. Do a rawflash enc,slim to DE_LG_WP50NB40-NB50_1.03_MK.bin, then a rawflash full,slim of DE_LG_WP50NB40-NB50_1.03_MK.bin, then a rawflash main,slim to DE_LG_BP60NB10_1.00_MK.bin *or* DE_LG_BU40N_1.00.bin if you want DVDFab compatibility.
With SDFTool Flasher, you would just do an encrypted flash to DE_LG_WP50NB40-NB50_1.03_MK.bin, then a RECOVER Drive, selecting DE_LG_WP50NB40-NB50_1.03_MK.bin from the pop-up window and then DE_LG_BP60NB10_1.00_MK.bin or DE_LG_BU40N_1.00.bin from the drop-down menu.
Or you can do as Billy said and e-mail him or Marty for an auto flasher.
