BU40N with OEM firmware A102 (MT1959): every flash reports "Done successfully" but firmware never changes
ewanmarkus
Post by ewanmarkus »
Hi all,
I'm trying to enable LibreDrive on an HL-DT-ST BD-RE BU40N for UHD backups and have hit a wall that doesn't match the usual failure modes. Hoping dcoke22 / MartyMcNuts / Billycar11 or anyone with A1xx experience can point me in the right direction.
Drive / setup
- HL-DT-ST BD-RE BU40N, firmware A102 (firmware date 2017-12-01 17:08), platform MT1959
- Connected over USB (machine has no SATA ports). Tested through two different USB-SATA bridges: ASMedia ASM1153E (174C:1153) and a JMicron bridge (152D:0583), both enumerating as USBSTOR (BOT)
- MakeMKV v1.18.4, Windows 11, makemkvcon run elevated
- MakeMKV drive info: LibreDrive: Possible, not yet enabled; Bus encryption flags: 1F; Highest AACS version: 82
Firmware file
HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin from the "all you need firmware pack" (2,097,152 bytes, SHA256 64900E8D69212F5D729B9DFA45EF0F317378DB8C8B48083A7CB99831235B5D57). Note: makemkvcon reports "Image already has DE byte set" when the de flag is used.
The symptom
Every single flash attempt completes both phases ("Sending flash image to drive" 100%, "Programming flash" 100%) and ends with "Done successfully", exit code 0. After a full power cycle (USB unplugged, drive re-enumerated, confirmed via fresh device arrival timestamps), the drive still reports A102. No error is ever raised: no 0x82052603 rollback error, no "Write DRAM NG", nothing. Nine attempts total across both bridges:
rawflash enc            (auto-selected "Using USB chipset workaround for Desktop drive handshake")
rawflash enc,slim       ("Using an USB slim drive handshake")
-f sdf.bin rawflash enc,slim
-f sdf.bin rawflash de,enc,slim
SDFtool Flasher v1.3.6, normal flash
SDFtool Flasher, with "Include boot" (on the first bridge)
plus earlier permutations of the above on the first bridge
Other observations
- Vendor-level reads work fine: MakeMKV successfully dumped and auto-uploaded the drive firmware for analysis (dump_FW_1BE3BD032CAD14D0F7B8.tgz), so the bridges pass vendor commands in at least the read direction
- "makemkvcon f -d X: dump full" is not available: dump auto only yields the user-data area (~70 KB), so full ROM dump appears disabled by this firmware
- With a UHD disc inserted (MKB v82): "Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive" followed by "LibreDrive compatible drive is required to open this disc"
- The drive reads CDs/DVDs/regular Blu-rays perfectly; it has never bricked despite all these attempts
My working theory
A102 looks like the ASUS OEM firmware (SBW-06D5H-U family). It seems to accept the flash image, ack every write, and then silently discard it at commit, rather than raising the rollback error seen in viewtopic.php?t=41801 (same A102 + MT1959 combo).
Questions
1. Is A102 known to silently ignore flash images over USB? Is there any DE/unlock-enabled intermediate image for A1xx that actually commits?
2. Is there anything in my command lines above that would explain "success but no change" other than firmware-side rejection?
3. Or is this drive simply a dead end for LibreDrive, and I should go the paid-flash route or replace the drive?
Happy to provide full logs or re-run any diagnostic. Thanks!
RibShark
Re: BU40N with OEM firmware A102 (MT1959): every flash reports "Done successfully" but firmware never changes
Post by RibShark »
It's possible your BU40N was actually originally a different slim drive that has since been recased and a fake label applied; a photo would clear this up.
When a drive like that is crossflashed to a firmware with a different boot code, attempting to reflash with the original boot code tends to produce that result (100%, successful message, but no firmware update). I recommend trying various boot codes in the flash command and seeing if one of them works:
rawflash enc,boot="MT1959 Boot BUP5"
rawflash enc,boot="MT1959 Boot BU5 "
rawflash enc,boot="MT1959 Boot BU51"
rawflash enc,boot="MT1959 Boot BUP1"
rawflash enc,boot="MT1959 Boot BUP3"
rawflash enc,boot="MT1959 Boot BP32"
rawflash enc,boot="MT1959 Boot BP52"
ewanmarkus wrote: Wed Jul 08, 2026 12:38 pm Hi all,
Drive / setup
Firmware file
The symptom
Other observations
My working theory
Questions
That firmware is not encrypted so you do not need enc. Just use SDFtool Flasher. It would have automatically set encrypted to off.
ewanmarkus
Solved, thank you MartyMcNuts. You nailed it: dropping enc was the fix.
For anyone who finds this later with the same "Done successfully but no change" symptom on an A102 / MT1959 BU40N: every one of my attempts had been using enc, and the drive silently discarded each one. The moment I flashed the plaintext image with no enc flag:
makemkvcon64.exe f --all-yes -d E: rawflash -i "HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin"
it committed on the first try. After a power cycle the drive now reports 1.03 (was A102), LibreDrive shows enabled, and a UHD disc opens cleanly (77 titles, zero "KEY EXCHANGE FAILURE", no "LibreDrive compatible drive is required"). The tell in the log: with enc you get a "Sending image in encrypted format" line; without enc that line is gone and it just works.
Thanks also to RibShark for the boot-code lead. For the record, in case it helps someone else: I did work through all of those boot codes (BUP5 / BU5 / BU51 / BUP1 / BUP3 / BP32 / BP52) plus the drive's own factory code, each verified with a full power cycle, and none committed while enc was in play. So on this drive it was purely the enc flag, not a boot-code mismatch.
Really appreciate the help, both of you. 4K ripping is up and running.
ewanmarkus wrote: Wed Jul 08, 2026 11:47 pm Solved, thank you MartyMcNuts. You nailed it: dropping enc was the fix.
Firmware dated before 2020 is not encrypted.
