Holler (bluray) "disc uses newer version of AACS protection"
briang2408
Post by briang2408 » Tue Jul 07, 2026 6:36 pm
Hi - the movie Holler (2021) on bluray comes up with a message saying: "This disc uses newer version of AACS protection". Anything I can do to make it work?
briang2408
Re: Holler (bluray) "disc uses newer version of AACS protection"
Post by briang2408 » Tue Jul 07, 2026 6:44 pm
Nevermind - upgraded to newer version of MKV and it works now :-)
Post by dcoke22 » Thu Jul 09, 2026 11:01 pm
lapwingpassion wrote: Thu Jul 09, 2026 3:15 am
briang2408 wrote: Tue Jul 07, 2026 6:36 pm Hi - the movie Holler (2021) on bluray comes up with a message saying: "This disc uses newer version of AACS protection". Anything I can do to make it work?
How did you fix it? Please share!
Can you copy and paste MakeMKV's log file into a post of it trying and failing on your disc?
I don't have that movie, but the blu-ray.com entry for Holler suggests it was released in May of 2026. As such it might be AACS v82. If that's the case, then like a 4K UHD, the dump should be emailed to svq@makemkv.com. A hashed key will eventually be produced and then MakeMKV can download that key and decrypt the disc. Additionally, you could also try the Public KeyDB.
But all that is speculation because we don't actually know what problem you've encountered. :)
